585,994 active members*
4,600 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > BallScrew Repair > How to repair linear motion bearing ballscrews (with internal circulation)
    Feb 2014
    Hi all,
    I too screwed up my ball screw ( now that's a tongue twister haha ) by taking the nut off the screw. I know there are quite a few tutorials showing how to repair a ball screw with external circulation, but not many on how to repair ball screws with internal circulation. I found this helpful video on youtube, it basically helped me fix my ball screw with internal circulation.
    Here is the link:
    Repacking Linearmotionbearings Ballscrews - YouTube
    Just so you know, I read that if you have found around 90% of the balls that came with the ball screw, it should still work if you fix it. I fixed mine and I didn't have all the ball bearings.
    Please show support by liking his video if you choose to.
    I hope this helps you out.
    Jun 2008
    51
    Re: How to repair linear motion bearing ballscrews (with internal circulation)
    One thing that I have been reading much into and seems to be missing from any 'how-to', is the ballscrew-nut preloading. While *I* don't know of the importance of preloading a nut, it seems to be a critical step.
    Additionally, for a "1-lock,1-floating" bearing ball-screw, the thrust-bearing must also be pre-loaded to the assembly...
    Any of the videos I've watched, and methods I've read about (regarding preloading the nut), they all talk about restraining the axial load by either using shims or springs - yet *none* provide an example of HOW precisely to do this. If it's a matter of restraining the ballscrew while tightening(?) another nut(?) against it as if using two nuts in a jam-nut configuration?
    All of the preload definitions aren't clear enough to me, however, because any tension introduced into the nut-balls by forcing a load against the nut will just simply unwind again once it's exercised in the opposite direction.
    (Some info: )
    Bearing Preload Facts and Information - NMB
    Preloading of Bearings
    Determining preload force
  1. linear motion bearing
    By sequel in forum DIY CNC Router Table Machines
    Last Post: 09-19-2013, 07:20 PM
  2. Open plain bushing bearing for use in linear motion
    By rdcd in forum Linear and Rotary Motion
    Last Post: 04-16-2010, 01:22 AM
  3. What Linear Motion Bearing is this
    By Hellbringer in forum Benchtop Machines
    Last Post: 08-22-2008, 03:55 PM
  4. 3 Bearing Linear motion?
    By 54Oval in forum Linear and Rotary Motion
    Last Post: 03-05-2007, 11:37 PM
  5. Very good info about linear motion and ballscrews.
    By DennisCNC in forum Linear and Rotary Motion
    Last Post: 11-18-2005, 02:39 PM
