A conversation in another thread made me decide to checkout how well the TTS collet fits into the spindle. I've seen this mentioned on the forum before, and since I've had tools pull out from time to time, I decided to see if this was part of the problem.
First I took an R8 collet from work (only marking is Taiwan) and checked the engagement on a bridgeport clone we have. It's hard to see much of a pattern, because it appears to contact evenly all the way around the collet. (Hopefully these pictures aren't too bad. The flash created some glare.)
Then I put the Tormach collet in the machine at work. Most of the contact appears to be at the splits in the collet, and at the bottom of the collet
I then took both collets home and did the same procedure on my 1100.
The Taiwan collet showed contact in larger areas, but still in only 1 spot on each of the three fingers.
Finally is the Tormach Collet in the 1100.
I'm tempted to try and remove the pin from the spindle, and lapp the collet into the spindle. The only other way I can think of is to stone the high spots away until it makes more even contact all the way around. That sounds like a lot of work, and would be easy to make things worse instead of better.
