585,930 active members*
3,715 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad Post Processors > mach3 post forASPIRE ON ROMAXX HS1
Results 1 to 8 of 8
    Jan 2011
    51
    Question mach3 post forASPIRE ON ROMAXX HS1
    Does anyone have a post processor for a Romaxx HS1 in Aspire 4.0 usimg Mach3?
    You just use the standard Mach3 posts. There's nothing in an Aspire post processor that would be specific to your Romaxx.
    Jan 2011
    51
    I upgraded from 3.5 to 4.0 and its adding tool changes to the code and I am using the Mach3 post with no ATC.
    also my z has lost its position as I start the the program its shows a t/c and I press start again and the z goes to
    the top and and trys to keep on going then it wants to drive to the table.It never did that before I upgraded.I am
    new to mach3 and Aspire so it could be error on my part?
    What post are you using?
    Jan 2011
    51
    I am using the non ATC Mach3 post.But its adding t/c and wont hold z zero wants to drive out of z limits +and-.
    Feb 2012
    149
    I use aspire4, with mach 3 _ATC and non ATC depending on the project. When I select multiple toolpaths with different tools and non_atc selected, aspire gives me a warning and does not allow saving the file. I must select the ATC processor to proceed. Are you saving multiple toolpaths with different tools into one file?
    Sent from my Transformer TF101 using Tapatalk
    Jul 2017
    348
    Yes you just use mach 3 pp for your romaxx mschine...OTE=macatoms;1436012]Does anyone have a post processor for a Romaxx HS1 in Aspire 4.0 usimg Mach3?
    Thanks[/QUOTE]
    Jul 2017
    348
    You need to change setting in mach3
    ...ignore tool change
    Thsts what i do...otherwise z will move up 1in and csn cause major issues
  1. Romaxx
    By lovebugjunkie in forum Commercial CNC Wood Routers
    Last Post: 08-24-2022, 03:45 AM
  2. Looking for Romaxx WD1--Used??
    By jascamera in forum Commercial CNC Wood Routers
    Last Post: 02-13-2012, 11:55 PM
  3. Romaxx router
    By evesaeth in forum Norwegian
    Last Post: 11-24-2011, 12:24 PM
  4. My Romaxx HS-1 Arrived
    By mattgatten in forum Commercial CNC Wood Routers
    Last Post: 02-12-2009, 03:37 PM
  5. Adding to a Romaxx cnc...
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 04-01-2008, 12:01 AM
