585,754 active members*
4,168 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Controlling Spindle Speed of BF20 with linuxcnc
    Feb 2014
    Hi everybody,
    I am new here. Hope I can ask something to the community.
    I have an Optimum BF20 installed stepper-motors on four axis, designed power-electronics and everything is working pretty fine with linuxcnc.
    Now I want to connect the spindle as well. I am able to read in the spindle-speed by using the signal used by the rpm-meter on the machine (there is an initiator collecting four signals per revolution). I am also able to set the spindle-direction by switching some relays. Is there an easy way how to set the spindle speed? I found a lot of information how to set up PID, I think this is the easier part. My problem is, that the potentiometer connected to the motor controller for controlling the speed is floating at roughly 150V AC - hurts a lot .
    I found some information that I need a 0-10V signal to set - ok I can do this from a pwm-signal and a low-pass filter. But how do I connect this to my floating 150V AC?? I made some trials with an optocoupler, but this is a big sh**, it's not linearly enough
    I'm afraid of destroying the controlling when forcing it to ground
    Does someone have some experience with this?
    Thanks a lot Schorsch
    Oct 2010
    1189
    Read about Vfd on my machine it is an Toshiba one it converts your 0..10 v Signal to frequency ..
    Gesendet von meinem SM-N9005 mit Tapatalk
  1. Looking for some "high"er speed spindle ideas for my bf20 clone
    By GreatNorthGnome in forum Benchtop Machines
    Last Post: 06-28-2014, 08:57 AM
  2. Powering and speed controlling new spindle motor
    By blayde in forum Spindles / VFD
    Last Post: 09-23-2013, 04:17 PM
  3. Linuxcnc controlling analog spindle drive
    By R.thayer in forum LinuxCNC (formerly EMC2)
    Last Post: 08-18-2012, 07:41 AM
  4. Controlling Router Spindle Start/Stop/Speed
    By AntonCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-17-2009, 09:04 PM
  5. controlling spindle speed
    Last Post: 01-15-2007, 06:43 AM
