585,975 active members*
4,615 visitors online*
    Jan 2008
    Handyman cnc retrofit with dmm servos
    I have finally started the retrofit i have planned and studied for 10 years. My machine is a handyman mill with bad control and glass scales and steppers. I plan to use dmm servos , mach3 or planet cnc cnc software . I am still researching breakout boards. parallel boards simply do not have enough inputs.I am considering automation technology 3 Axis CNC USB Card Mach3 200KHz. It comes with mach3 addons ,one important is auto tool height. I havent found a real accurate homing sequence yet. I wnated more than 5 inputs for + and - jog all axis, mpg input, estop ,feed hold ,auto tool height sensor, feed rate pot. The decisions seem harder than implementation.
    First mod is to put a manual motor on the Knee . I tried a pulley system installed inside knee ,goes down but just slips going up. I am now building a double gear reduction drive hung from knee crank shaft with a reversable garage door opener motor. I will post pics only if it is sucessful.Next is to make a new front cover to allow y servo to be inside knee(originally outside at a 45 deg ). I will also need to make a new thrust bearing holder ,as it was part of the old y axis motor mount.I would like to hear about the best breakout boards with lots of inputs.
    Oct 2010
    1189
    Re: Handyman cnc retrofit with dmm servos
    i do a bridgeport 412 I retrofit had same issue we use an PCI card which can drive servos much faster and has R485 bus for relays and MPG as well as 4 times 10 Pins for whatever you need.
    i use it for ATC MPG and so on but it is not Mach3 able but i am sure you can find some PCI card also for Mach3 if mach3 is not a must i can share my info with you
  1. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  2. Millpwr Retrofit-Retrofit on Bridgeport
    By pofo in forum Bridgeport / Hardinge Mills
    Last Post: 03-08-2010, 12:19 AM
  3. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  4. camsoft retrofit to a anilam crusader retrofit
    By bowlingmac in forum CamSoft Products
    Last Post: 07-25-2008, 03:00 AM
  5. plasma table retrofit: smart servos or closed loop steppers?
    By Josh Leber in forum Waterjet General Topics
    Last Post: 03-25-2006, 04:25 AM
