585,962 active members*
3,885 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP 7000 PARAMETERS
Results 1 to 18 of 18
    Oct 2012
    59
    OSP 7000 PARAMETERS
    We have an early 90's model LB series lathe, 10 inch chuck, OSP7000 controller and live tooling. I am looking for a parameters
    manual or the initial parameter settings for this early DOS based controller.
    Feb 2009
    6028
    Not that early, and not DOS, although some commands are the same.
    parameters are shipped with the floppy disk set. should be a file name like A.TOP
    If you lost parameters, (board fail?) you WILL need to re-load the exec anyways. When you do, it will put all the values back to factory.
    Oct 2012
    59
    Yep board fail...sort of...wouldn't boot all the way, we kept getting the alarm "1-1" at boot. To make a long story short we traced down the
    board, and the red illuminated LED on that board corresponded to the exact boot up alarm etc. So from there we didn't know what to do, like there's
    the board now what? We decided to check the battery right next to the faulty board, pulled the whole card (with the opus7000 battery), checked the battery, fine,
    re-installed it and viola. No more red light.
    We then were able to install the Okuma system floppy disks (1 thru 7) with an explicit set of detailed OKUMA instructions. This allowed the
    OSP 7000 controller to boot up completely and the machine turned on like it was supposed to.
    Then I think there was an alarm that corresponded to some parameter like word 41, I set 41 to 1, then another for word parameter like 73 or something,
    manually set it to one and cleared all alarms.
    But now the controller is in a constant state of variable limit ON ( green limit light allways on) and it is difficult to find the correct number (because limits are like 10,909.90) and its like where in that number is the machine work work envelope? I cant just CAL 0.
    We have several recent PBU (parameter backup disks) that came with the machine but it won't read them, we keep getting an error. That is why I am looking for parameters.
    AND maybe some X and Z stroke limit #'s from another same model machine that I can put in ours.
    We got this machine used 5 months ago and it was a lemon...Long story, but the controller worked fine then. It sat for 6 months, we got the turret fixed and now
    these controller probs.
    Thanks for the reply!
    Aug 2011
    2517
    here's the parameters from another lemon (1996 LT25-M with OSP7000, 10" chucks and live tooling).
    I doubt they can be used as-is though. I think you just need to set up your limits and your machine will be ok.
    Attached Files Attached Files
    Oct 2012
    59
    thanks fordav11 !
    Oct 2012
    59
    BTW, you wouldn't have any tips or tricks for setting the limits after a recovery?
    Apr 2009
    1262
    In the back of your machine in the electrical cabinet there should be a "Management Data Card" that has your Stroke end Limits, PR Zero Offsets, and Zero sets for your particular machine recorded. When Strokes are set, Variable limits will be set automatically.
    Check there first...
    Best reagrds,
    Feb 2009
    6028
    I usually just manually set the limits to 999 and -999, along with the user limits, then jog to close to the limit switches and enter the current value for each.factory limits may not help if the encoder has ever been changed.
    Sent from my G-Tab Quantum using Tapatalk
    Mar 2009
    1982
    or, in addition to previous explanations,
    Look how VZOFZ is changing with commands CALL 0, CALL 1000. This gives you answer, what is the value of machine coordinates unit. You can find a page with machine axis data.
    Easy to calculate encoder zero offset or limits.
    Oct 2012
    59
    Thanks, a paper with the stroke end limits came with the machine...first after much trial and trib. I ended up through optional parameter 3 bits 0 1 changing the machine from metric to inch ( metric after syst. software re-install ), then I was able to keep adding + or - till I got the #'s set to the ones that came with machine. Then was able to escape the constant state of VP/VNLVz/x on and VIOLA! I can now MANUALLY move XZorC wherever and CAL MY limits wherever I need them! THANKS guys for the fantastic support!
    But now this has made way to a new set of problems that I hope you guys can help us with !
    1: the input units are .0001, so when I ADD 1.0 I actually get ADD .0001! so ADD one inch is typed like ADD 1000.0 please help!
    2: a live tooling program that I have ran and completely proven on our new Genos live machine, will on the old lemon run up till the point where the C & X axes would otherwise move simultaneously , then all axial movement stops and the buffer continues to read and run the prog as if it was still running AND finish thru M02, but no axial physical machine movement!!! Please help!
    Aug 2011
    2517
    1. there's a parameter to set the amount that is added. looks like you have it set to microns or tenths of microns?
    2. post the program here and we'll have a look, otherwise we can't help you.
    Mar 2009
    1982
    1. set stop point in the part program just before C axis engage
    M01 or M00.
    2. when part program stops (conditional program stop) turn on the single step mode. Continue the program with green button.
    3. Go step by step through the part program. I guess, the error message pops up
    Oct 2012
    59
    Thanks again! I will try the m stops thing monday.
    Any idea witch param that input units is (optional , long word etc...) ?
    Here is the text:
    M110
    M146
    M16
    G00X2.50C30T1111SB=3000
    G94Z.5M13
    G01 Z-.125F10.0
    G103C330L1.125F20.0
    C270L1.125
    C210L1.125
    C150L1.125
    C90L1.125
    C30L1.125
    G00X2.90Z.5C30
    G01 Z-.125 F10.0
    G103C330L1.325F20.0
    C270L1.325
    C210L1.325
    C150L1.325
    C90L1.325
    C30L1.325
    G00X2.50Z.5C30
    G01 Z-.250F10.0
    G103C330L1.125F20.0
    C270L1.125
    C210L1.125
    C150L1.125
    C90L1.125
    C30L1.125
    G00X2.90Z.5C30
    G01 Z-.250 F10.0
    G103C330L1.325F20.0
    C270L1.325
    C210L1.325
    C150L1.325
    C90L1.325
    C30L1.325
    G00 X20 Z20 M12
    G95 M109
    M02
    Mar 2009
    1982
    G94 ?
    Aug 2011
    2517
    G94 is feed per minute. that's ok because he's milling.
    A Genos is a much more capable machine. You generally can't run programs from newer machines on old pieces of crap as-is without modifications. Are you sure your lemon has G103. its an option.
    Oct 2012
    59
    I will check that.
    Oct 2012
    59
    Hey guys, just want to let anyone interested in on the resolution:
    It was OPTIONAL parameter #3 changing bit 1 from zero to one...(if that makes any sense) that changed the input units from .0001 to 1.0 and allowed the
    machine to run that prog...all day long sweet suzie !
    Oct 2022
    Re: OSP 7000 PARAMETERS
    Im looking for parameter for OSP7000 M
    OKUMA MC40VB 1995
  1. What drivers for hermes v 7000
    By ropanach in forum Engraving Machines
    Last Post: 02-16-2013, 09:25 PM
  2. New Hermes Vanguard 7000
    By hershamboy in forum Engraving Machines
    Last Post: 01-12-2013, 01:59 AM
  3. OSP 7000 Metric to English
    By bbarber80 in forum Okuma
    Last Post: 05-24-2012, 01:08 PM
  4. OSP 7000 LU-45 file format??
    By TriumphMachine in forum Okuma
    Last Post: 09-03-2010, 10:18 PM
