586,000 active members*
5,031 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Job setup for 2 or more vices in Edgecam
Results 1 to 14 of 14
    May 2009
    17
    Red face Job setup for 2 or more vices in Edgecam
    Hi, How do I write a program in Edgecam to output G54, G55 work co-ordinates for 2 or more vices?I edit it in the code generator but cannot save it as a file to call up again
    Jun 2008
    125
    I've done something similar before and what I did was to customise a simple 3 axis post processor.
    All they had to do was program as normal but at the start of the program we had a menu where they selected how many work offsets they were using, then the post would output each tool movement as a sub and repeat for G54, G55, G56 etc etc.
    Takes a little digging under the surface of Edgecam/Code Wizard but got good results.
    Sep 2008
    24
    Hi Meegers, that sounds very interesting.
    I do it this way:
    Tool 1 - Rapidmove - Cycle - Index G55 - Translate - Index G56 - Translate -
    Toolchange - Index G54
    New Tool etc etc............ Its a pain.
    I know it's much to ask for, but is it possible you wanna share a post that can do that ?
    Or tell step by step how to tweak one ?
    I would be very grateful !
    Jun 2008
    125
    I can't let you have the post but I'll try and tell you how it works and give you some ideas. I'll create a new post for it. Basically the post will output two programs.
    The first looks like this ...
    O0001
    (SUBS SETUP)
    (T1 H1 D1 - 40MM FACE MILL)
    (T2 H2 D2 - 16.0 MM MULTI-FLUTE END MILL)
    (T3 H3 D3 - 18MM MULTI-FLUTE ENDMILL)
    (T4 H4 D4 - 8.5 MM JOBBER DRILL)
    (T5 H5 D5 - 16.0 MM SLOT DRILL - 2 FLUTE)
    G00 G17 G21 G40 G49 G54 G80 G90 G94
    G53 Z0. M09
    M01
    (40MM FACE MILL)
    T1 M06
    G90 G54
    S1111 M03
    G43 H1 D1 M08
    G54 M97 P100
    /G55 M97 P100
    /G56 M97 P100
    /G57 M97 P100
    G53 Z0. M09
    M01
    (16.0 MM MULTI-FLUTE END MILL)
    T2 M06
    G90 G54
    S2222 M03
    G43 H2 D2 M88
    G54 M97 P101
    /G55 M97 P101
    /G56 M97 P101
    /G57 M97 P101
    G53 Z0. M09
    M01
    (18MM MULTI-FLUTE ENDMILL)
    T3 M06
    G90 G54
    S3333 M03
    G43 H3 D3
    G54 M97 P102
    /G55 M97 P102
    /G56 M97 P102
    /G57 M97 P102
    G53 Z0. M09
    M01
    (8.5 MM JOBBER DRILL)
    T4 M06
    G90 G54
    S4444 M03
    G43 H4 D4 M08
    G54 M97 P103
    /G55 M97 P103
    /G56 M97 P103
    /G57 M97 P103
    G53 Z0. M09
    M01
    (16.0 MM SLOT DRILL - 2 FLUTE)
    T5 M06
    G90 G54
    S5555 M03
    G43 H5 D5 M08
    G54 M97 P104
    /G55 M97 P104
    /G56 M97 P104
    /G57 M97 P104
    G53 Z0. M09
    M01
    T4 M06
    G90 G54
    S6666 M03
    G43 H4 D4 M08
    G54 M97 P105
    /G55 M97 P105
    /G56 M97 P105
    /G57 M97 P105
    G53 Z0. M09
    G00 G53 Y0.
    M30
    and the second program, containing the subs, looks like this .....
    N100
    (40MM FACE MILL)
    G00 X100. Y68.683
    Z25.
    Z7.5
    G01 Z2.5 F1500.0
    X75.
    X-75.
    G03 X-82. Y61.683 I0. J-7.
    G01 Y50.683
    G03 X-75. Y43.683 I7. J0.
    G01 X75.
    G02 X82. Y36.683 I0. J-7.
    G01 Y25.683
    G02 X75. Y18.683 I-7. J0.
    G01 X-75.
    G03 X-82. Y11.683 I0. J-7.
    G01 Y0.683
    G03 X-75. Y-6.317 I7. J0.
    G01 X75.
    G02 X82. Y-13.317 I0. J-7.
    G01 Y-24.317
    G02 X75. Y-31.317 I-7. J0.
    G01 X-75.
    G03 X-82. Y-38.317 I0. J-7.
    G01 Y-49.317
    G03 X-75. Y-56.317 I7. J0.
    G01 X75.
    X100.
    G00 Z25.
    Y68.683
    Z5.
    G01 Z0.
    X75.
    X-75.
    G01 Y50.683
    G01 X75.
    G01 Y25.683
    G01 X-75.
    G01 Y0.683
    G01 X75.
    G01 Y-24.317
    G01 X-75.
    G01 Y-49.317
    G01 X75.
    X100.
    G00 Z25.
    M99
    N101
    G00 X21.66 Y22.791
    Z5.
    G02 Z1.878 I3.747 J-7.012 F1500.0
    G02 Z-1.244 I3.747 J-7.012
    G02 Z-4.366 I3.747 J-7.012
    G02 X31.028 Y21.401 Z-5. I3.747 J-7.012
    G02 X30.803 Y21.617 I-5.621 J-5.622
    G01 X31.028 Y21.401
    X31.979 Y20.45
    G03 X32.896 Y20.025 I1.412 J1.845
    G01 X32.93 Y20.045
    G03 X30.983 Y21.994 I-5.122 J-3.171
    G03 X29.728 Y22.846 I-6.659 J-8.452
    G01 X29.611 Y22.864
    X29.615 Y22.815
    X29.642 Y22.805
    X29.589 Y22.896
    X20.356 Y32.757
    X20.176 Y32.884
    X20.045 Y32.93
    X20.009 Y32.883
    G03 X21.864 Y30.565 I6.766 J3.514
    G01 X22.532 Y29.897
    X22.832 Y29.716
    X22.947 Y29.687
    X22.948 Y29.736
    X21.743 Y31.331
    X21.661 Y31.273
    X40.93 Y0.186
    X40.91 Y23.119
    G03 X38.421 Y26.511 I-4.222 J-0.488
    G02 X30.498 Y33.175 I22.491 J34.785
    G02 X25.874 Y39.391 I40.469 J34.928
    G03 X22.716 Y40.93 I-3.158 J-2.472
    G01 X2.374 Y40.907
    G03 X1.883 Y39.233 I0.212 J-0.971
    G01 X47.398 Y-6.251
    G03 X48.93 Y-5.414 I0.538 J0.837
    G01 X48.907 Y28.365
    G03 X46.713 Y31.272 I-3.567 J-0.411
    G02 X42.56 Y33.373 I8.389 J21.737
    G02 X36.631 Y38.311 I18.295 J27.993
    G02 X32.428 Y44.18 I26.497 J23.418
    G03 X30.774 Y47.56 I-28.129 J-11.666
    G03 X27.961 Y48.93 I-2.813 J-2.204
    G01 X-16.915 Y48.907
    G03 X-17.404 Y47.206 I0.213 J-0.982
    G01 X18.607 Y11.194
    X54.618 Y-24.817
    X56.703 Y-24.148
    X57.03 Y-18.918
    Y34.052
    X56.971 Y35.944
    X56.754 Y36.634
    G03 X52.242 Y37.836 I-7.097 J-17.574
    G01 X51.079 Y38.171
    X47.295 Y39.945
    G02 X42.841 Y43.511 I15.166 J23.502
    G02 X39.728 Y47.69 I21.764 J19.467
    G01 X39.058 Y49.187
    X38.171 Y51.079
    G02 X37.284 Y54.862 I62.885 J16.738
    G01 X36.634 Y56.754
    X35.944 Y56.971
    X34.052 Y57.03
    X-18.918
    X-24.593 Y56.676
    G03 X-32.141 Y54.862 I5.281 J-38.601
    G01 X-32.161 Y54.843
    X-34.052 Y54.133
    X-34.387 Y52.97
    X-34.052 Y52.517
    X-32.732 Y51.079
    X51.079 Y-32.732
    X52.517 Y-34.052
    X52.97 Y-34.387
    X54.133 Y-34.052
    X54.843 Y-32.161
    X54.862 Y-32.141
    G03 X56.703 Y-24.148 I-34.439 J12.141
    G01 X56.604 Y-24.142
    X24.49 Y7.687
    G02 Z-8.122 I1.166 J7.863
    G02 X31.278 Y21.172 Z-10. I1.166 J7.863
    G02 X31.053 Y21.388 I-5.622 J-5.622
    G01 X31.278 Y21.172
    X32.094 Y20.356
    X32.88 Y20.046
    X32.909 Y20.063
    G03 X30.964 Y21.992 I-5.238 J-3.338
    G03 X29.86 Y22.638 I-1.859 J-1.911
    G01 X29.864 Y22.587
    X29.891 Y22.576
    X29.838 Y22.667
    X20.594 Y32.549
    X20.063 Y32.909
    X20.03 Y32.863
    G03 X22.606 Y29.966 I8.425 J4.898
    G01 X22.722 Y29.939
    X22.725 Y29.99
    X21.534 Y31.597
    X21.453 Y31.538
    X40.909 Y0.227
    X40.889 Y23.122
    G03 X38.494 Y26.443 I-4.146 J-0.466
    G02 X30.464 Y33.19 I22.662 J35.118
    G02 X25.889 Y39.347 I40.503 J34.871
    G03 X22.716 Y40.909 I-3.173 J-2.444
    G01 X2.416 Y40.886
    G03 X1.924 Y39.212 I0.211 J-0.971
    G01 X47.378 Y-6.209
    G03 X48.909 Y-5.373 I0.537 J0.836
    G01 X48.886 Y28.351
    G03 X46.694 Y31.26 I-3.571 J-0.411
    G02 X42.55 Y33.359 I9.246 J23.39
    G02 X36.604 Y38.319 I18.538 J28.27
    G02 X32.486 Y44.039 I27.142 J23.878
    G03 X30.764 Y47.538 I-32.924 J-14.041
    G03 X27.946 Y48.909 I-2.818 J-2.208
    G01 X-16.876 Y48.886
    G03 X-17.365 Y47.187 I0.213 J-0.981
    G01 X18.62 Y11.203
    X54.604 Y-24.782
    X56.698 Y-24.114
    X57.009 Y-18.918
    Y34.052
    X56.95 Y35.944
    X56.754 Y36.613
    G03 X52.221 Y37.836 I-7.442 J-18.578
    G01 X51.079 Y38.15
    X47.295 Y39.924
    G02 X42.821 Y43.511 I15.52 J23.942
    G02 X39.728 Y47.669 I21.987 J19.587
    G01 X39.037 Y49.187
    X38.15 Y51.079
    X37.836 Y52.221
    X37.264 Y54.862
    X36.613 Y56.754
    X35.944 Y56.95
    X34.052 Y57.009
    X-18.918
    X-24.593 Y56.655
    G03 X-32.12 Y54.862 I5.525 J-39.902
    G01 X-32.161 Y54.822
    X-34.052 Y54.112
    X-34.367 Y52.97
    X-34.052 Y52.538
    X-32.711 Y51.079
    X51.079 Y-32.711
    X52.538 Y-34.052
    X52.97 Y-34.367
    X54.112 Y-34.052
    X54.822 Y-32.161
    X54.862 Y-32.12
    G03 X56.698 Y-24.114 I-36.421 J12.563
    G01 X56.598 Y-24.105
    X18.605 Y12.131
    G02 Z-13.122 I7.268 J3.221
    G02 X31.495 Y20.974 Z-14.5 I7.268 J3.221
    G02 I-5.622 J-5.622
    G01 X32.193 Y20.276
    X32.891 Y20.079
    G03 X30.948 Y21.99 I-5.351 J-3.498
    G03 X30.077 Y22.442 I-1.114 J-1.08
    G01 X30.081 Y22.388
    X30.108 Y22.378
    X30.055 Y22.468
    X20.607 Y32.537
    X20.078 Y32.891
    X20.048 Y32.845
    G03 X22.412 Y30.184 I7.542 J4.323
    G01 X22.532 Y30.16
    X22.536 Y30.214
    X21.347 Y31.822
    X21.266 Y31.764
    G00 Z5.
    X-18.653 Y43.525
    Z-8.9
    Z-9.9
    G01 X40.891 Y0.264 Z-14.5
    X40.869 Y23.139
    G03 X38.684 Y26.301 I-4.001 J-0.429
    G02 X30.434 Y33.205 I22.661 J35.467
    G02 X25.668 Y39.591 I49.556 J41.948
    G03 X22.726 Y40.891 I-2.942 J-2.679
    G01 X2.452 Y40.868
    G03 X1.961 Y39.194 I0.212 J-0.971
    G01 X47.359 Y-6.173
    G03 X48.891 Y-5.336 I0.538 J0.837
    G01 X48.868 Y28.338
    G03 X46.676 Y31.25 I-3.576 J-0.411
    G02 X42.541 Y33.347 I9.002 J22.871
    G02 X36.58 Y38.326 I18.756 J28.518
    G02 X32.571 Y43.857 I28.383 J24.786
    G01 X30.986 Y47.185
    G03 X27.933 Y48.891 I-3.053 J-1.879
    G01 X-16.841 Y48.868
    G03 X-17.33 Y47.171 I0.213 J-0.98
    G01 X54.82 Y-24.95
    G03 X56.69 Y-24.083 I0.676 J0.993
    G01 X56.991 Y-18.918
    Y34.052
    X56.932 Y35.944
    X56.754 Y36.595
    G03 X52.202 Y37.836 I-7.774 J-19.544
    G01 X51.079 Y38.132
    X47.295 Y39.905
    G02 X42.802 Y43.511 I15.84 J24.338
    G02 X39.905 Y47.295 I30.511 J26.36
    G01 X38.132 Y51.079
    X37.836 Y52.202
    X37.245 Y54.862
    X36.595 Y56.754
    X35.944 Y56.932
    X34.052 Y56.991
    X-18.918
    X-24.593 Y56.636
    G03 X-32.102 Y54.862 I5.76 J-41.163
    G01 X-32.161 Y54.803
    X-34.052 Y54.094
    X-34.348 Y52.97
    X-34.052 Y52.556
    X-32.693 Y51.079
    X51.079 Y-32.693
    X52.556 Y-34.052
    X52.97 Y-34.348
    X54.094 Y-34.052
    X54.803 Y-32.161
    X54.862 Y-32.102
    G03 X56.69 Y-24.083 I-38.094 J12.899
    G01 X56.59 Y-24.072
    G00 Z5.
    X-30.767 Y-28.457
    G02 Z1.878 I2.574 J-7.521
    G02 Z-1.244 I2.574 J-7.521
    G02 Z-4.366 I2.574 J-7.521
    G02 X-21.743 Y-31.331 Z-5. I2.574 J-7.521
    G02 X-21.93 Y-31.082 I-6.45 J-4.647
    G01 X-21.743 Y-31.331
    G03 X-20.045 Y-32.93 I3.141 J1.634
    G01 X-20.009 Y-32.883
    G03 X-21.864 Y-30.565 I-6.766 J-3.514
    G01 X-22.532 Y-29.897
    X-22.832 Y-29.716
    X-22.947 Y-29.687
    X-22.948 Y-29.736
    X-22.95 Y-29.788
    X-23.072 Y-29.762
    X-23.381 Y-29.577
    X-31.028 Y-21.401
    G03 X-32.883 Y-20.009 I-4.742 J-4.386
    G01 X-32.93 Y-20.045
    G03 X-30.983 Y-21.994 I5.122 J3.171
    G03 X-29.728 Y-22.846 I6.626 J8.407
    G01 X-29.61 Y-22.863
    X-29.614 Y-22.815
    X-31.028 Y-21.401
    X-31.099 Y-21.471
    X-40.93 Y-0.186
    X-40.91 Y-23.119
    G03 X-38.421 Y-26.511 I4.222 J0.488
    G02 X-30.498 Y-33.175 I-22.491 J-34.785
    G02 X-25.874 Y-39.391 I-40.469 J-34.928
    G03 X-22.716 Y-40.93 I3.158 J2.472
    G01 X-2.374 Y-40.907
    G03 X-1.883 Y-39.233 I-0.212 J0.971
    G01 X-47.398 Y6.251
    G03 X-48.93 Y5.414 I-0.538 J-0.837
    G01 X-48.907 Y-28.365
    G03 X-46.713 Y-31.272 I3.567 J0.411
    G02 X-42.56 Y-33.373 I-8.389 J-21.737
    G02 X-36.631 Y-38.311 I-18.295 J-27.993
    G02 X-32.428 Y-44.18 I-26.497 J-23.418
    G03 X-30.774 Y-47.56 I28.129 J11.666
    G03 X-27.961 Y-48.93 I2.813 J2.204
    G01 X16.915 Y-48.907
    G03 X17.404 Y-47.206 I-0.213 J0.982
    G01 X-18.607 Y-11.194
    X-54.618 Y24.817
    X-56.703 Y24.148
    X-57.03 Y18.918
    Y-34.052
    X-56.971 Y-35.944
    X-56.754 Y-36.634
    G03 X-52.242 Y-37.836 I7.097 J17.574
    G01 X-51.079 Y-38.171
    X-47.295 Y-39.945
    G02 X-42.841 Y-43.511 I-15.166 J-23.502
    G02 X-39.728 Y-47.69 I-21.764 J-19.467
    G01 X-39.058 Y-49.187
    X-38.171 Y-51.079
    G02 X-37.284 Y-54.862 I-62.885 J-16.738
    G01 X-36.634 Y-56.754
    X-35.944 Y-56.971
    X-34.052 Y-57.03
    X18.918
    X24.593 Y-56.676
    G03 X32.141 Y-54.862 I-5.281 J38.601
    G01 X32.161 Y-54.843
    X34.052 Y-54.133
    X34.387 Y-52.97
    X34.052 Y-52.517
    X32.732 Y-51.079
    X-51.079 Y32.732
    X-52.517 Y34.052
    X-52.97 Y34.387
    X-54.133 Y34.052
    X-54.843 Y32.161
    X-54.862 Y32.141
    G03 X-56.703 Y24.148 I34.439 J-12.141
    G01 X-56.604 Y24.142
    X-30.378 Y-43.833
    G02 Z-8.122 I2.401 J7.579
    G02 X-21.534 Y-31.597 Z-10. I2.401 J7.579
    G02 X-21.722 Y-31.347 I-6.443 J-4.657
    G01 X-21.534 Y-31.597
    G03 X-20.063 Y-32.909 I2.533 J1.36
    G01 X-20.03 Y-32.863
    G03 X-22.606 Y-29.966 I-8.426 J-4.898
    G01 X-22.722 Y-29.939
    X-22.725 Y-29.99
    X-22.73 Y-30.047
    X-22.855 Y-30.025
    X-23.172 Y-29.843
    X-31.743 Y-20.745
    G03 X-32.862 Y-20.029 I-2.694 J-2.976
    G01 X-32.909 Y-20.063
    G03 X-30.964 Y-21.992 I5.238 J3.338
    G03 X-29.86 Y-22.637 I1.854 J1.904
    G01 X-29.864 Y-22.586
    X-31.278 Y-21.172
    X-31.349 Y-21.243
    X-40.909 Y-0.227
    X-40.889 Y-23.122
    G03 X-38.494 Y-26.443 I4.146 J0.466
    G02 X-30.464 Y-33.19 I-22.662 J-35.118
    G02 X-25.889 Y-39.347 I-40.503 J-34.871
    G03 X-22.716 Y-40.909 I3.173 J2.444
    G01 X-2.416 Y-40.886
    G03 X-1.924 Y-39.212 I-0.211 J0.971
    G01 X-47.378 Y6.209
    G03 X-48.909 Y5.373 I-0.537 J-0.836
    G01 X-48.886 Y-28.351
    G03 X-46.694 Y-31.26 I3.571 J0.411
    G02 X-42.55 Y-33.359 I-9.246 J-23.39
    G02 X-36.604 Y-38.319 I-18.538 J-28.27
    G02 X-32.486 Y-44.039 I-27.142 J-23.878
    G03 X-30.764 Y-47.538 I32.924 J14.041
    G03 X-27.946 Y-48.909 I2.818 J2.208
    G01 X16.876 Y-48.886
    G03 X17.365 Y-47.187 I-0.213 J0.981
    G01 X-54.844 Y24.991
    G03 X-56.698 Y24.114 I-0.668 J-0.984
    G01 X-57.009 Y18.918
    Y-34.052
    X-56.95 Y-35.944
    X-56.754 Y-36.613
    G03 X-52.221 Y-37.836 I7.442 J18.578
    G01 X-51.079 Y-38.15
    X-47.295 Y-39.924
    G02 X-42.821 Y-43.511 I-15.52 J-23.942
    G02 X-39.728 Y-47.669 I-21.987 J-19.587
    G01 X-39.037 Y-49.187
    X-38.15 Y-51.079
    X-37.836 Y-52.221
    X-37.264 Y-54.862
    X-36.613 Y-56.754
    X-35.944 Y-56.95
    X-34.052 Y-57.009
    X18.918
    X24.593 Y-56.655
    G03 X32.12 Y-54.862 I-5.525 J39.902
    G01 X32.161 Y-54.822
    X34.052 Y-54.112
    X34.367 Y-52.97
    X34.052 Y-52.538
    X32.711 Y-51.079
    X-51.079 Y32.711
    X-52.538 Y34.052
    X-52.97 Y34.367
    X-54.112 Y34.052
    X-54.822 Y32.161
    X-54.862 Y32.12
    G03 X-56.698 Y24.114 I36.421 J-12.563
    G01 X-56.598 Y24.105
    X-35.496 Y-38.467
    G02 Z-13.122 I7.693 J2.005
    G02 X-21.347 Y-31.822 Z-14.5 I7.693 J2.005
    G02 X-21.534 Y-31.572 I-6.456 J-4.64
    G01 X-21.347 Y-31.822
    G03 X-20.078 Y-32.891 I1.987 J1.072
    G01 X-20.048 Y-32.845
    G03 X-22.413 Y-30.184 I-7.542 J-4.323
    G01 X-22.532 Y-30.16
    X-22.536 Y-30.214
    X-22.541 Y-30.271
    X-22.667 Y-30.251
    X-22.986 Y-30.069
    X-31.733 Y-20.785
    G03 X-32.844 Y-20.048 I-2.883 J-3.141
    G01 X-32.891 Y-20.079
    G03 X-30.948 Y-21.99 I5.351 J3.498
    G03 X-30.077 Y-22.442 I1.112 J1.077
    G01 X-30.08 Y-22.388
    X-31.495 Y-20.974
    X-31.565 Y-21.044
    G00 Z5.
    X18.653 Y-43.525
    Z-8.9
    Z-9.9
    G01 X-40.891 Y-0.264 Z-14.5
    X-40.869 Y-23.139
    G03 X-38.684 Y-26.301 I4.001 J0.429
    G02 X-30.434 Y-33.205 I-22.661 J-35.467
    G02 X-25.668 Y-39.591 I-49.556 J-41.948
    G03 X-22.726 Y-40.891 I2.942 J2.679
    G01 X-2.452 Y-40.868
    G03 X-1.961 Y-39.194 I-0.212 J0.971
    G01 X-47.359 Y6.173
    G03 X-48.891 Y5.336 I-0.538 J-0.837
    G01 X-48.868 Y-28.338
    G03 X-46.676 Y-31.25 I3.576 J0.411
    G02 X-42.541 Y-33.347 I-9.002 J-22.871
    G02 X-36.58 Y-38.326 I-18.756 J-28.518
    G02 X-32.571 Y-43.857 I-28.383 J-24.786
    G01 X-30.986 Y-47.185
    G03 X-27.933 Y-48.891 I3.053 J1.879
    G01 X16.841 Y-48.868
    G03 X17.33 Y-47.171 I-0.213 J0.98
    G01 X-54.82 Y24.95
    G03 X-56.69 Y24.083 I-0.676 J-0.993
    G01 X-56.991 Y18.918
    Y-34.052
    X-56.932 Y-35.944
    X-56.754 Y-36.595
    G03 X-52.202 Y-37.836 I7.774 J19.544
    G01 X-51.079 Y-38.132
    X-47.295 Y-39.905
    G02 X-42.802 Y-43.511 I-15.84 J-24.338
    G02 X-39.905 Y-47.295 I-30.511 J-26.36
    G01 X-38.132 Y-51.079
    X-37.836 Y-52.202
    X-37.245 Y-54.862
    X-36.595 Y-56.754
    X-35.944 Y-56.932
    X-34.052 Y-56.991
    X18.918
    X24.593 Y-56.636
    G03 X32.102 Y-54.862 I-5.76 J41.163
    G01 X32.161 Y-54.803
    X34.052 Y-54.094
    X34.348 Y-52.97
    X34.052 Y-52.556
    X32.693 Y-51.079
    X-51.079 Y32.693
    X-52.556 Y34.052
    X-52.97 Y34.348
    X-54.094 Y34.052
    X-54.803 Y32.161
    X-54.862 Y32.102
    G03 X-56.69 Y24.083 I38.094 J-12.899
    G01 X-56.59 Y24.072
    G00 Z5.
    X83.875 Y-74.299
    Z-4.
    G01 Z-5.
    G03 X82.52 Y-74.853 I-0.143 J-1.582
    G01 X75.707 Y-81.556
    G02 X71.903 Y-82.848 I-3.638 J4.464
    G01 X63.212 Y-82.825
    G02 X62.995 Y-81.527 I0.181 J0.697
    G01 X69.136 Y-76.741
    X72.227 Y-73.814
    G03 X80.3 Y-64.658 I-42.467 J45.58
    G03 X82.659 Y-60.414 I-7.294 J6.833
    G03 X82.85 Y-58.59 I-7.471 J1.703
    G01 X82.829 Y-45.627
    G03 X81.956 Y-45.592 I-0.443 J-0.138
    G01 X79.276 Y-51.43
    X75.559 Y-57.557
    G02 X72.35 Y-61.838 I-56.531 J39.026
    G02 X66.481 Y-68.244 I-38.574 J29.447
    G02 X58.689 Y-74.781 I-43.284 J43.683
    G02 X54.85 Y-77.2 I-23.853 J33.595
    G02 X47.509 Y-81.08 I-20.556 J30.014
    G02 X43.367 Y-82.849 I-16.492 J32.881
    G00 Z5.
    X-83.875 Y74.299
    Z-4.
    G01 Z-5.
    G03 X-82.52 Y74.853 I0.143 J1.582
    G01 X-75.707 Y81.556
    G02 X-71.903 Y82.848 I3.638 J-4.464
    G01 X-63.212 Y82.825
    G02 X-62.995 Y81.527 I-0.181 J-0.697
    G01 X-69.136 Y76.741
    X-72.227 Y73.814
    G03 X-80.3 Y64.658 I42.467 J-45.58
    G03 X-82.659 Y60.414 I7.294 J-6.833
    G03 X-82.85 Y58.59 I7.471 J-1.703
    G01 X-82.829 Y45.627
    G03 X-81.956 Y45.592 I0.443 J0.138
    G01 X-79.276 Y51.43
    X-75.559 Y57.557
    G02 X-72.35 Y61.838 I56.531 J-39.026
    G02 X-66.481 Y68.244 I38.574 J-29.447
    G02 X-58.689 Y74.781 I43.284 J-43.683
    G02 X-54.85 Y77.2 I23.853 J-33.595
    G02 X-47.509 Y81.08 I20.556 J-30.014
    G02 X-43.367 Y82.849 I16.492 J-32.881
    G00 Z5.
    X-72.969 Y-83.875
    Z-4.
    G01 Z-5.
    Y-83.363
    G03 X-74.977 Y-81.538 I-6.191 J-4.795
    G02 X-82.848 Y-72.971 I16.259 J22.84
    G00 Z5.
    X72.969 Y83.875
    Z-4.
    G01 Z-5.
    Y83.363
    G03 X74.977 Y81.538 I6.191 J4.795
    G02 X81.972 Y74.268 I-15.067 J-21.5
    G02 X82.048 Y70.708 I-3.84 J-1.863
    G01 X79.081 Y62.198
    G03 X78.85 Y59.609 I6.799 J-1.91
    G01 X78.842
    X78.933 Y58.646
    X78.992 Y56.754
    Y-18.918
    X78.933 Y-20.81
    X78.578 Y-26.485
    X78.342 Y-28.377
    X77.277 Y-34.052
    X75.563 Y-39.728
    G02 X73.139 Y-45.403 I-55.35 J20.281
    G01 X72.311 Y-47.295
    X71.188 Y-49.187
    X70.006 Y-51.079
    X69.997 Y-51.147
    G02 X64.321 Y-58.892 I-48.882 J29.869
    G01 X58.892 Y-64.321
    X54.103 Y-68.105
    X52.97 Y-68.883
    X51.147 Y-69.997
    X51.079 Y-70.006
    X49.187 Y-71.188
    X47.295 Y-72.311
    X41.62 Y-74.853
    X39.728 Y-75.563
    X37.836 Y-76.095
    X34.052 Y-77.277
    X28.377 Y-78.342
    X26.485 Y-78.578
    X20.81 Y-78.933
    X18.918 Y-78.992
    X-56.754
    G02 X-62.43 Y-78.519 I0.977 J46.025
    G02 X-68.105 Y-76.332 I6.623 J25.64
    G02 X-77.928 Y-64.321 I9.813 J18.048
    G01 X-78.519 Y-62.43
    G02 X-78.992 Y-56.754 I45.552 J6.653
    G01 Y18.918
    X-78.933 Y20.81
    X-78.578 Y26.485
    X-78.342 Y28.377
    X-77.277 Y34.052
    X-75.563 Y39.728
    G02 X-73.139 Y45.403 I55.35 J-20.281
    G01 X-72.311 Y47.295
    X-71.188 Y49.187
    X-70.006 Y51.079
    X-69.997 Y51.147
    G02 X-64.321 Y58.892 I48.882 J-29.869
    G01 X-58.892 Y64.321
    X-54.103 Y68.105
    X-52.97 Y68.883
    X-51.147 Y69.997
    X-51.079 Y70.006
    X-49.187 Y71.188
    X-47.295 Y72.311
    X-41.62 Y74.853
    X-39.728 Y75.563
    X-37.836 Y76.095
    X-34.052 Y77.277
    X-28.377 Y78.342
    X-26.485 Y78.578
    X-20.81 Y78.933
    X-18.918 Y78.992
    X56.754
    G02 X62.43 Y78.519 I-0.977 J-46.025
    G02 X68.105 Y76.332 I-6.623 J-25.64
    G02 X77.928 Y64.321 I-9.813 J-18.048
    G02 X78.755 Y60.538 I-10.07 J-4.184
    G01 X78.842 Y59.609
    X78.942 Y59.621
    G00 Z5.
    X83.875 Y-74.308
    Z-9.
    G01 Z-10.
    G03 X82.52 Y-74.863 I-0.143 J-1.583
    G01 X75.716 Y-81.557
    G02 X71.909 Y-82.848 I-3.636 J4.46
    G01 X63.226 Y-82.825
    G02 X63.008 Y-81.525 I0.181 J0.698
    G01 X69.353 Y-76.568
    X74.336 Y-71.711
    G03 X80.328 Y-64.633 I-41.75 J41.425
    G03 X82.765 Y-59.875 I-7.016 J6.595
    G01 X82.85 Y-58.605
    X82.829 Y-45.652
    G03 X81.955 Y-45.617 I-0.444 J-0.139
    G01 X79.286 Y-51.431
    X75.561 Y-57.568
    G02 X72.357 Y-61.841 I-56.435 J38.97
    G02 X66.491 Y-68.244 I-38.718 J29.584
    G02 X61.52 Y-72.598 I-26.819 J25.604
    G02 X54.893 Y-77.183 I-27.219 J32.26
    G02 X47.536 Y-81.073 I-20.443 J29.767
    G02 X43.393 Y-82.849 I-16.251 J32.187
    G00 Z5.
    X-83.875 Y74.308
    Z-9.
    G01 Z-10.
    G03 X-82.52 Y74.863 I0.143 J1.583
    G01 X-75.716 Y81.557
    G02 X-71.909 Y82.848 I3.636 J-4.46
    G01 X-63.226 Y82.825
    G02 X-63.008 Y81.525 I-0.181 J-0.698
    G01 X-69.353 Y76.568
    X-74.336 Y71.711
    G03 X-80.328 Y64.633 I41.75 J-41.425
    G03 X-82.765 Y59.875 I7.016 J-6.595
    G01 X-82.85 Y58.605
    X-82.829 Y45.652
    G03 X-81.955 Y45.617 I0.444 J0.139
    G01 X-79.286 Y51.431
    X-75.561 Y57.568
    G02 X-72.357 Y61.841 I56.435 J-38.97
    G02 X-66.491 Y68.244 I38.718 J-29.584
    G02 X-61.52 Y72.598 I26.819 J-25.604
    G02 X-54.893 Y77.183 I27.219 J-32.26
    G02 X-47.536 Y81.073 I20.443 J-29.767
    G02 X-43.393 Y82.849 I16.251 J-32.187
    G00 Z5.
    X-72.974 Y-83.875
    Z-9.
    G01 Z-10.
    Y-83.363
    G03 X-74.984 Y-81.541 I-6.228 J-4.855
    G02 X-82.848 Y-72.976 I16.224 J22.789
    G00 Z5.
    X72.974 Y83.875
    Z-9.
    G01 Z-10.
    Y83.363
    G03 X74.984 Y81.541 I6.229 J4.855
    G02 X81.975 Y74.277 I-15.104 J-21.531
    G02 X82.051 Y70.713 I-3.839 J-1.865
    G01 X79.09 Y62.192
    G03 X78.86 Y59.605 I6.82 J-1.909
    G01 X78.853 Y59.604
    X78.942 Y58.646
    X79.001 Y56.754
    Y-18.918
    X78.942 Y-20.81
    X78.588 Y-26.485
    G02 X77.564 Y-32.652 I-53.86 J5.772
    G01 X77.287 Y-34.052
    X75.572 Y-39.728
    G02 X73.149 Y-45.403 I-55.32 J20.269
    G01 X72.321 Y-47.295
    X68.892 Y-52.97
    G02 X66.054 Y-56.754 I-48.788 J33.637
    G02 X62.744 Y-60.538 I-28.273 J21.397
    G01 X60.852 Y-62.43
    G02 X56.536 Y-66.213 I-21.944 J20.678
    G02 X51.079 Y-70.016 I-21.55 J25.112
    G01 X49.187 Y-71.198
    X47.295 Y-72.321
    X41.62 Y-74.863
    G02 X37.836 Y-76.105 I-9.237 J21.759
    G01 X34.052 Y-77.287
    X28.377 Y-78.351
    X26.485 Y-78.588
    X20.81 Y-78.942
    X18.918 Y-79.001
    X-56.754
    G02 X-62.43 Y-78.529 I0.977 J46.017
    G01 X-64.321 Y-77.937
    G02 X-71.789 Y-73.78 I6.104 J19.751
    G01 X-73.78 Y-71.789
    G02 X-77.937 Y-64.321 I15.594 J13.572
    G01 X-78.529 Y-62.43
    G02 X-79.001 Y-56.754 I45.545 J6.653
    G01 Y18.918
    X-78.942 Y20.81
    X-78.588 Y26.485
    G02 X-77.564 Y32.652 I53.86 J-5.772
    G01 X-77.287 Y34.052
    X-75.572 Y39.728
    G02 X-73.149 Y45.403 I55.32 J-20.269
    G01 X-72.321 Y47.295
    X-68.892 Y52.97
    G02 X-66.054 Y56.754 I48.788 J-33.637
    G02 X-62.744 Y60.538 I28.273 J-21.397
    G01 X-60.852 Y62.43
    G02 X-56.536 Y66.213 I21.944 J-20.678
    G02 X-51.079 Y70.016 I21.55 J-25.112
    G01 X-49.187 Y71.198
    X-47.295 Y72.321
    X-41.62 Y74.863
    G02 X-37.836 Y76.105 I9.237 J-21.759
    G01 X-34.052 Y77.287
    X-28.377 Y78.351
    X-26.485 Y78.588
    X-20.81 Y78.942
    X-18.918 Y79.001
    X56.754
    G02 X62.43 Y78.529 I-0.977 J-46.017
    G01 X64.321 Y77.937
    G02 X71.789 Y73.78 I-6.104 J-19.751
    G01 X73.78 Y71.789
    G02 X77.937 Y64.321 I-15.594 J-13.572
    G02 X78.765 Y60.538 I-10.071 J-4.185
    G01 X78.853 Y59.604
    X78.952 Y59.617
    G00 Z5.
    X83.875 Y-74.318
    Z-14.
    G01 Z-15.
    G03 X82.52 Y-74.872 I-0.143 J-1.583
    G01 X75.725 Y-81.557
    G02 X71.919 Y-82.848 I-3.635 J4.46
    G01 X63.24 Y-82.825
    G02 X63.022 Y-81.524 I0.182 J0.699
    G01 X66.603 Y-78.785
    G03 X72.246 Y-73.814 I-26.233 J35.465
    G03 X80.357 Y-64.608 I-42.854 J45.933
    G03 X82.765 Y-59.892 I-7.007 J6.55
    G01 X82.85 Y-58.62
    X82.828 Y-45.678
    G03 X81.953 Y-45.642 I-0.444 J-0.139
    G01 X79.295 Y-51.431
    X75.562 Y-57.58
    G02 X72.364 Y-61.845 I-56.925 J39.354
    G02 X66.501 Y-68.244 I-38.862 J29.722
    G02 X61.578 Y-72.56 I-26.631 J25.408
    G02 X54.938 Y-77.165 I-27.457 J32.504
    G02 X47.544 Y-81.075 I-20.43 J29.683
    G02 X43.419 Y-82.849 I-16.035 J31.619
    G00 Z5.
    X-83.875 Y74.318
    Z-14.
    G01 Z-15.
    G03 X-82.52 Y74.872 I0.143 J1.583
    G01 X-75.725 Y81.557
    G02 X-71.919 Y82.848 I3.635 J-4.46
    G01 X-63.24 Y82.825
    G02 X-63.022 Y81.524 I-0.182 J-0.699
    G01 X-66.603 Y78.785
    G03 X-72.246 Y73.814 I26.233 J-35.465
    G03 X-80.357 Y64.608 I42.854 J-45.933
    G03 X-82.765 Y59.892 I7.007 J-6.55
    G01 X-82.85 Y58.62
    X-82.828 Y45.678
    G03 X-81.953 Y45.642 I0.444 J0.139
    G01 X-79.295 Y51.431
    X-75.562 Y57.58
    G02 X-72.364 Y61.845 I56.925 J-39.354
    G02 X-66.501 Y68.244 I38.862 J-29.722
    G02 X-61.578 Y72.56 I26.631 J-25.408
    G02 X-54.938 Y77.165 I27.457 J-32.504
    G02 X-47.544 Y81.075 I20.43 J-29.683
    G02 X-43.419 Y82.849 I16.035 J-31.619
    G00 Z5.
    X-72.989 Y-83.875
    Z-14.
    G01 Z-15.
    Y-83.363
    G03 X-74.999 Y-81.54 I-6.237 J-4.856
    G02 X-82.848 Y-72.992 I16.272 J22.821
    G00 Z5.
    X72.989 Y83.875
    Z-14.
    G01 Z-15.
    Y83.363
    G03 X74.999 Y81.54 I6.237 J4.856
    G02 X81.974 Y74.292 I-15.149 J-21.559
    G02 X82.056 Y70.726 I-3.843 J-1.872
    G01 X79.102 Y62.168
    G03 X78.872 Y59.587 I6.862 J-1.911
    G01 X78.864 Y59.586
    X78.952 Y58.646
    X79.011 Y56.754
    Y-18.918
    X78.952 Y-20.81
    X78.597 Y-26.485
    X78.361 Y-28.377
    X77.297 Y-34.052
    X75.582 Y-39.728
    G02 X73.158 Y-45.403 I-55.292 J20.258
    G01 X72.331 Y-47.295
    X68.902 Y-52.97
    G02 X66.064 Y-56.754 I-48.761 J33.616
    G02 X62.754 Y-60.538 I-28.283 J21.406
    G01 X60.862 Y-62.43
    G02 X56.546 Y-66.213 I-21.946 J20.68
    G02 X51.079 Y-70.025 I-21.761 J25.383
    G01 X49.187 Y-71.207
    X47.295 Y-72.331
    X41.62 Y-74.873
    G02 X37.836 Y-76.114 I-9.231 J21.741
    G01 X34.052 Y-77.297
    X28.377 Y-78.361
    X26.485 Y-78.597
    X20.81 Y-78.952
    X18.918 Y-79.011
    X-56.754
    G02 X-62.43 Y-78.538 I0.976 J46.01
    G01 X-66.213 Y-77.297
    G02 X-73.78 Y-71.799 I8.792 J20.058
    G02 X-77.947 Y-64.321 I15.567 J13.575
    G01 X-78.538 Y-62.43
    G02 X-79.011 Y-56.754 I45.537 J6.652
    G01 Y18.918
    X-78.952 Y20.81
    X-78.597 Y26.485
    X-78.361 Y28.377
    X-77.297 Y34.052
    X-75.582 Y39.728
    G02 X-73.158 Y45.403 I55.292 J-20.258
    G01 X-72.331 Y47.295
    X-68.902 Y52.97
    G02 X-66.064 Y56.754 I48.761 J-33.616
    G02 X-62.754 Y60.538 I28.283 J-21.406
    G01 X-60.862 Y62.43
    G02 X-56.546 Y66.213 I21.946 J-20.68
    G02 X-51.079 Y70.025 I21.761 J-25.383
    G01 X-49.187 Y71.207
    X-47.295 Y72.331
    X-41.62 Y74.873
    G02 X-37.836 Y76.114 I9.231 J-21.741
    G01 X-34.052 Y77.297
    X-28.377 Y78.361
    X-26.485 Y78.597
    X-20.81 Y78.952
    X-18.918 Y79.011
    X56.754
    G02 X62.43 Y78.538 I-0.976 J-46.01
    G01 X66.213 Y77.297
    G02 X73.78 Y71.799 I-8.792 J-20.058
    G02 X77.297 Y66.213 I-19.634 J-16.26
    G01 X78.538 Y62.43
    X78.864 Y59.586
    X78.963 Y59.598
    G00 Z5.
    X83.875 Y-74.328
    Z-19.
    G01 Z-20.
    G03 X82.52 Y-74.882 I-0.143 J-1.582
    G01 X75.735 Y-81.557
    G02 X71.929 Y-82.848 I-3.635 J4.46
    G01 X63.255 Y-82.825
    G02 X63.036 Y-81.522 I0.182 J0.7
    G01 X66.613 Y-78.785
    G03 X72.256 Y-73.814 I-26.235 J35.467
    G03 X81.827 Y-62.557 I-46.085 J48.882
    G03 X82.85 Y-58.634 I-6.47 J3.781
    G01 X82.828 Y-45.703
    G03 X81.952 Y-45.667 I-0.444 J-0.139
    G01 X79.272 Y-51.486
    X75.564 Y-57.591
    G02 X72.371 Y-61.848 I-56.886 J39.341
    G02 X66.51 Y-68.244 I-39.007 J29.86
    G02 X61.579 Y-72.568 I-26.672 J25.451
    G02 X54.986 Y-77.145 I-27.47 J32.531
    G02 X47.575 Y-81.067 I-20.323 J29.44
    G02 X43.445 Y-82.849 I-15.839 J31.032
    G00 Z5.
    X-83.875 Y74.328
    Z-19.
    G01 Z-20.
    G03 X-82.52 Y74.882 I0.143 J1.582
    G01 X-75.735 Y81.557
    G02 X-71.929 Y82.848 I3.635 J-4.46
    G01 X-63.255 Y82.825
    G02 X-63.036 Y81.522 I-0.182 J-0.7
    G01 X-66.613 Y78.785
    G03 X-72.256 Y73.814 I26.235 J-35.467
    G03 X-81.827 Y62.557 I46.085 J-48.882
    G03 X-82.85 Y58.634 I6.47 J-3.781
    G01 X-82.828 Y45.703
    G03 X-81.952 Y45.667 I0.444 J0.139
    G01 X-79.272 Y51.486
    X-75.564 Y57.591
    G02 X-72.371 Y61.848 I56.886 J-39.341
    G02 X-66.51 Y68.244 I39.007 J-29.86
    G02 X-61.579 Y72.568 I26.672 J-25.451
    G02 X-54.986 Y77.145 I27.47 J-32.531
    G02 X-47.575 Y81.067 I20.323 J-29.44
    G02 X-43.445 Y82.849 I15.839 J-31.032
    G00 Z5.
    X-73.005 Y-83.875
    Z-19.
    G01 Z-20.
    Y-83.363
    G03 X-75.013 Y-81.538 I-6.245 J-4.858
    G02 X-82.848 Y-73.007 I16.32 J22.852
    G00 Z5.
    X73.005 Y83.875
    Z-19.
    G01 Z-20.
    Y83.363
    G03 X75.013 Y81.538 I6.245 J4.858
    G02 X81.973 Y74.306 I-15.19 J-21.583
    G02 X82.057 Y70.741 I-3.84 J-1.873
    G01 X79.108 Y62.185
    G03 X78.88 Y59.599 I6.866 J-1.907
    G01 X78.872
    X78.962 Y58.646
    X79.021 Y56.754
    Y-18.918
    X78.962 Y-20.81
    X78.607 Y-26.485
    X78.37 Y-28.377
    X77.306 Y-34.052
    X75.592 Y-39.728
    G02 X73.78 Y-44.022 I-30.99 J10.542
    G01 X72.34 Y-47.295
    X68.911 Y-52.97
    G02 X66.074 Y-56.754 I-48.733 J33.595
    G02 X62.763 Y-60.538 I-28.293 J21.415
    G01 X60.871 Y-62.43
    G02 X56.556 Y-66.213 I-21.948 J20.682
    G02 X51.079 Y-70.035 I-21.974 J25.656
    G01 X47.295 Y-72.34
    X41.62 Y-74.882
    G02 X37.836 Y-76.124 I-9.225 J21.722
    G01 X34.052 Y-77.306
    X28.377 Y-78.37
    X26.485 Y-78.607
    X20.81 Y-78.962
    X18.918 Y-79.021
    X-56.754
    G02 X-62.43 Y-78.548 I0.976 J46.004
    G01 X-66.213 Y-77.306
    G02 X-73.78 Y-71.808 I8.792 J20.057
    G02 X-77.957 Y-64.321 I15.54 J13.577
    G01 X-78.548 Y-62.43
    G02 X-79.021 Y-56.754 I45.531 J6.652
    G01 Y18.918
    X-78.962 Y20.81
    X-78.607 Y26.485
    X-78.37 Y28.377
    X-77.306 Y34.052
    X-75.592 Y39.728
    G02 X-73.78 Y44.022 I30.99 J-10.542
    G01 X-72.34 Y47.295
    X-68.911 Y52.97
    G02 X-66.074 Y56.754 I48.733 J-33.595
    G02 X-62.763 Y60.538 I28.293 J-21.415
    G01 X-60.871 Y62.43
    G02 X-56.556 Y66.213 I21.948 J-20.682
    G02 X-51.079 Y70.035 I21.974 J-25.656
    G01 X-47.295 Y72.34
    X-41.62 Y74.882
    G02 X-37.836 Y76.124 I9.225 J-21.722
    G01 X-34.052 Y77.306
    X-28.377 Y78.37
    X-26.485 Y78.607
    X-20.81 Y78.962
    X-18.918 Y79.021
    X56.754
    G02 X62.43 Y78.548 I-0.976 J-46.004
    G01 X66.213 Y77.306
    G02 X73.78 Y71.808 I-8.792 J-20.057
    G02 X77.306 Y66.213 I-19.598 J-16.259
    G01 X78.548 Y62.43
    X78.872 Y59.599
    X78.972 Y59.611
    G00 Z5.
    X83.875 Y-74.337
    Z-24.
    G01 Z-25.
    G03 X82.52 Y-74.891 I-0.143 J-1.583
    G01 X75.745 Y-81.557
    G02 X71.939 Y-82.848 I-3.636 J4.461
    G01 X63.267 Y-82.825
    G02 X63.046 Y-81.52 I0.182 J0.702
    G01 X66.886 Y-78.595
    G03 X74.368 Y-71.707 I-37.815 J48.582
    G01 X76.915 Y-68.961
    G03 X81.825 Y-62.572 I-58.042 J49.692
    G03 X82.85 Y-58.649 I-6.445 J3.779
    G01 X82.828 Y-45.729
    G03 X81.95 Y-45.692 I-0.445 J-0.139
    G01 X79.448 Y-51.198
    X75.566 Y-57.602
    G02 X70.155 Y-64.549 I-69.151 J48.279
    G01 X64.393 Y-70.302
    X58.855 Y-74.692
    G02 X55.293 Y-76.962 I-19.769 J27.088
    G02 X47.605 Y-81.058 I-21.262 J30.646
    G02 X43.47 Y-82.849 I-15.656 J30.482
    G00 Z5.
    X-83.875 Y74.337
    Z-24.
    G01 Z-25.
    G03 X-82.52 Y74.891 I0.143 J1.583
    G01 X-75.745 Y81.557
    G02 X-71.939 Y82.848 I3.636 J-4.461
    G01 X-63.267 Y82.825
    G02 X-63.046 Y81.52 I-0.182 J-0.702
    G01 X-66.886 Y78.595
    G03 X-74.368 Y71.707 I37.815 J-48.582
    G01 X-76.915 Y68.961
    G03 X-81.825 Y62.572 I58.042 J-49.692
    G03 X-82.85 Y58.649 I6.445 J-3.779
    G01 X-82.828 Y45.729
    G03 X-81.95 Y45.692 I0.445 J0.139
    G01 X-79.448 Y51.198
    X-75.566 Y57.602
    G02 X-70.155 Y64.549 I69.151 J-48.279
    G01 X-64.393 Y70.302
    X-58.855 Y74.692
    G02 X-55.293 Y76.962 I19.769 J-27.088
    G02 X-47.605 Y81.058 I21.262 J-30.646
    G02 X-43.47 Y82.849 I15.656 J-30.482
    G00 Z5.
    X-73.02 Y-83.875
    Z-24.
    G01 Z-25.
    Y-83.363
    G03 X-75.027 Y-81.537 I-6.253 J-4.858
    G02 X-82.848 Y-73.022 I16.367 J22.884
    G00 Z5.
    X73.02 Y83.875
    Z-24.
    G01 Z-25.
    Y83.363
    G03 X75.027 Y81.537 I6.253 J4.858
    G02 X81.972 Y74.321 I-15.23 J-21.607
    G02 X82.058 Y70.756 I-3.838 J-1.876
    G01 X79.114 Y62.202
    G03 X78.889 Y59.612 I6.87 J-1.903
    G01 X78.881 Y59.611
    X78.971 Y58.646
    X79.03 Y56.754
    Y-18.918
    X78.971 Y-20.81
    X78.616 Y-26.485
    G02 X77.564 Y-32.681 I-49.634 J5.244
    G01 X77.316 Y-34.052
    X75.601 Y-39.728
    G02 X73.78 Y-44.032 I-30.332 J10.296
    G01 X72.35 Y-47.295
    X68.921 Y-52.97
    X66.083 Y-56.754
    X64.321 Y-58.93
    X58.93 Y-64.321
    X54.141 Y-68.105
    G02 X51.079 Y-70.044 I-14.813 J20.005
    G01 X47.295 Y-72.35
    X41.62 Y-74.892
    G02 X37.836 Y-76.134 I-9.219 J21.704
    G01 X34.052 Y-77.316
    X28.377 Y-78.38
    X26.485 Y-78.616
    X20.81 Y-78.971
    X18.918 Y-79.03
    X-56.754
    G02 X-62.43 Y-78.557 I0.976 J45.996
    G01 X-66.213 Y-77.316
    G02 X-77.316 Y-66.213 I8.36 J19.463
    G01 X-78.557 Y-62.43
    G02 X-79.03 Y-56.754 I45.523 J6.652
    G01 Y18.918
    X-78.971 Y20.81
    X-78.616 Y26.485
    G02 X-77.564 Y32.681 I49.634 J-5.244
    G01 X-77.316 Y34.052
    X-75.601 Y39.728
    G02 X-73.78 Y44.032 I30.332 J-10.296
    G01 X-72.35 Y47.295
    X-68.921 Y52.97
    X-66.083 Y56.754
    X-64.321 Y58.93
    X-58.93 Y64.321
    X-54.141 Y68.105
    G02 X-51.079 Y70.044 I14.813 J-20.005
    G01 X-47.295 Y72.35
    X-41.62 Y74.892
    G02 X-37.836 Y76.134 I9.219 J-21.704
    G01 X-34.052 Y77.316
    X-28.377 Y78.38
    X-26.485 Y78.616
    X-20.81 Y78.971
    X-18.918 Y79.03
    X56.754
    G02 X62.43 Y78.557 I-0.976 J-45.996
    G01 X66.213 Y77.316
    G02 X75.188 Y69.997 I-8.219 J-19.24
    G02 X77.966 Y64.321 I-16.27 J-11.484
    G02 X78.794 Y60.538 I-10.074 J-4.185
    G01 X78.881 Y59.611
    X78.98 Y59.624
    G00 Z5.
    X83.875 Y-74.346
    Z-28.5
    G01 Z-29.5
    G03 X82.52 Y-74.9 I-0.143 J-1.583
    G01 X75.753 Y-81.557
    G02 X71.947 Y-82.848 I-3.635 J4.461
    G01 X63.282 Y-82.825
    G02 X63.059 Y-81.518 I0.182 J0.703
    G01 X66.892 Y-78.599
    G03 X74.378 Y-71.706 I-37.99 J48.767
    G03 X79.155 Y-66.164 I-33.959 J34.108
    G03 X82.091 Y-62.088 I-21.312 J18.442
    G03 X82.85 Y-58.663 I-6.695 J3.28
    G01 X82.828 Y-45.752
    G03 X81.949 Y-45.715 I-0.446 J-0.139
    G01 X79.45 Y-51.21
    X75.568 Y-57.612
    G02 X72.385 Y-61.854 I-58.133 J40.304
    G02 X66.528 Y-68.245 I-39.285 J30.123
    G02 X61.364 Y-72.752 I-28.618 J27.576
    G02 X55.293 Y-76.971 I-25.997 J30.933
    G02 X47.63 Y-81.051 I-21.17 J30.521
    G02 X43.494 Y-82.849 I-15.501 J30.016
    G00 Z5.
    X-83.875 Y74.346
    Z-28.5
    G01 Z-29.5
    G03 X-82.52 Y74.9 I0.143 J1.583
    G01 X-75.753 Y81.557
    G02 X-71.947 Y82.848 I3.635 J-4.461
    G01 X-63.282 Y82.825
    G02 X-63.059 Y81.518 I-0.182 J-0.703
    G01 X-66.892 Y78.599
    G03 X-74.378 Y71.706 I37.99 J-48.767
    G03 X-79.155 Y66.164 I33.959 J-34.108
    G03 X-82.091 Y62.088 I21.312 J-18.442
    G03 X-82.85 Y58.663 I6.695 J-3.28
    G01 X-82.828 Y45.752
    G03 X-81.949 Y45.715 I0.446 J0.139
    G01 X-79.45 Y51.21
    X-75.568 Y57.612
    G02 X-72.385 Y61.854 I58.133 J-40.304
    G02 X-66.528 Y68.245 I39.285 J-30.123
    G02 X-61.364 Y72.752 I28.618 J-27.576
    G02 X-55.293 Y76.971 I25.997 J-30.933
    G02 X-47.63 Y81.051 I21.17 J-30.521
    G02 X-43.494 Y82.849 I15.501 J-30.016
    G00 Z5.
    X-73.034 Y-83.875
    Z-28.5
    G01 Z-29.5
    Y-83.363
    G03 X-75.04 Y-81.535 I-6.26 J-4.859
    G02 X-82.848 Y-73.036 I16.411 J22.913
    G00 Z5.
    X73.034 Y83.875
    Z-28.5
    G01 Z-29.5
    Y83.363
    G03 X75.04 Y81.535 I6.26 J4.859
    G02 X81.971 Y74.334 I-15.266 J-21.627
    G02 X82.059 Y70.77 I-3.836 J-1.878
    G01 X79.12 Y62.218
    G03 X78.896 Y59.624 I6.873 J-1.9
    G01 X78.888 Y59.623
    X78.98 Y58.646
    X79.039 Y56.754
    Y-18.918
    X78.98 Y-20.81
    X78.625 Y-26.485
    G02 X77.564 Y-32.69 I-48.514 J5.104
    G01 X77.325 Y-34.052
    X75.61 Y-39.728
    G02 X73.78 Y-44.041 I-29.774 J10.088
    G01 X72.359 Y-47.295
    X68.93 Y-52.97
    X66.092 Y-56.754
    X64.321 Y-58.939
    X58.939 Y-64.321
    X54.15 Y-68.105
    G02 X51.079 Y-70.053 I-14.614 J19.644
    G01 X47.295 Y-72.359
    X41.62 Y-74.901
    X39.728 Y-75.61
    X39.37 Y-75.672
    X34.052 Y-77.325
    X28.377 Y-78.389
    X26.485 Y-78.625
    X20.81 Y-78.98
    X18.918 Y-79.039
    X-56.754
    G02 X-62.43 Y-78.566 I0.975 J45.99
    G01 X-66.213 Y-77.325
    G02 X-73.78 Y-71.827 I8.792 J20.058
    G02 X-77.325 Y-66.213 I17.292 J14.844
    G01 X-78.566 Y-62.43
    G02 X-79.039 Y-56.754 I45.517 J6.651
    G01 Y18.918
    X-78.98 Y20.81
    X-78.625 Y26.485
    G02 X-77.564 Y32.69 I48.514 J-5.104
    G01 X-77.325 Y34.052
    X-75.61 Y39.728
    G02 X-73.78 Y44.041 I29.774 J-10.088
    G01 X-72.359 Y47.295
    X-68.93 Y52.97
    X-66.092 Y56.754
    X-64.321 Y58.939
    X-58.939 Y64.321
    X-54.15 Y68.105
    G02 X-51.079 Y70.053 I14.614 J-19.644
    G01 X-47.295 Y72.359
    X-41.62 Y74.901
    X-39.728 Y75.61
    X-39.37 Y75.672
    X-34.052 Y77.325
    X-28.377 Y78.389
    X-26.485 Y78.625
    X-20.81 Y78.98
    X-18.918 Y79.039
    X56.754
    G02 X62.43 Y78.566 I-0.975 J-45.99
    G01 X66.213 Y77.325
    G02 X73.78 Y71.827 I-8.792 J-20.058
    G02 X77.325 Y66.213 I-19.528 J-16.256
    G01 X78.566 Y62.43
    X78.888 Y59.623
    X78.988 Y59.635
    G00 Z5.
    M99
    N102
    G00 X-33.524 Y-18.119
    Z5.
    Z-10.
    G01 Z-15. F1500.0
    G03 X-33.035 Y-20.905 I1.637 J-1.148
    G02 X-21.139 Y-32.582 I-26.185 J-38.573
    G03 X-19.777 Y-33.207 I1.388 J1.228
    G01 X-19.671 Y-33.178
    X-19.591 Y-33.1
    X-19.516 Y-32.842
    X-19.556 Y-32.528
    X-19.719 Y-32.252
    X-32.265 Y-19.706
    X-32.541 Y-19.544
    X-32.855 Y-19.503
    X-33.112 Y-19.579
    X-33.191 Y-19.659
    X-33.133 Y-21.319
    X-33.641 Y-24.866
    G03 X-32.411 Y-26.966 I2.382 J-0.015
    G02 X-23.82 Y-36.807 I-25.64 J-31.054
    G03 X-21.95 Y-37.707 I1.87 J1.493
    G01 X-9.25
    G03 X-8.855 Y-36.752 I0. J0.559
    G01 X-36.773 Y-8.834
    G03 X-37.727 Y-9.229 I-0.395 J-0.395
    G01 X-37.718 Y-21.97
    G03 X-36.255 Y-24.172 I2.44 J0.034
    G02 X-34.313 Y-25.771 I-2.803 J-5.381
    G02 X-34.065 Y-27.23 I-1.889 J-1.073
    G01 X-34.488 Y-29.571
    G03 X-33.75 Y-31.809 I2.432 J-0.439
    G02 X-26.397 Y-41.334 I-23.245 J-25.546
    G03 X-24.645 Y-42.207 I1.752 J1.321
    G01 X1.614
    G03 X2.009 Y-41.252 I0. J0.559
    G01 X-41.281 Y2.038
    G03 X-42.235 Y1.643 I-0.395 J-0.395
    G01 X-42.216 Y-24.621
    G03 X-41.076 Y-26.584 I2.262 J0.001
    G02 X-35.371 Y-30.464 I-12.342 J-24.277
    G02 X-35.073 Y-32.122 I-1.552 J-1.135
    G01 X-35.738 Y-34.474
    G03 X-34.86 Y-37.034 I2.385 J-0.613
    G02 X-29.268 Y-45.791 I-24.046 J-21.518
    G03 X-27.578 Y-46.707 I1.69 J1.102
    G01 X12.478
    G03 X12.873 Y-45.752 I0. J0.559
    G01 X-45.79 Y12.91
    G03 X-46.743 Y12.515 I-0.395 J-0.395
    G01 X-46.713 Y-27.585
    G03 X-45.469 Y-29.462 I2.04 J0.001
    G02 X-36.884 Y-35.068 I-10.886 J-26.048
    G02 X-36.513 Y-37.06 I-1.677 J-1.343
    G01 X-37.256 Y-39.41
    G03 X-36.499 Y-42.095 I2.503 J-0.744
    G02 X-32.386 Y-50.291 I-24.467 J-17.41
    G03 X-30.836 Y-51.207 I1.55 J0.854
    G01 X21.199
    X23.045 Y-51.038
    G03 X23.438 Y-49.953 I-0.058 J0.634
    G01 X-49.956 Y23.44
    G03 X-51.072 Y23.036 I-0.463 J-0.463
    G01 X-51.249 Y20.004
    X-51.211 Y-30.831
    G03 X-49.939 Y-32.566 I1.82 J0.001
    G02 X-38.356 Y-39.895 I-7.737 J-25.046
    G02 X-38.169 Y-41.836 I-1.628 J-1.136
    G01 X-39.183 Y-44.119
    G03 X-38.896 Y-46.692 I2.374 J-1.038
    G02 X-35.939 Y-55.177 I-19.718 J-11.632
    G01 X-35.813 Y-55.648
    X-34.389 Y-55.707
    X21.404
    G03 X32.91 Y-53.3 I-1.433 J35.562
    G01 X32.897 Y-53.209
    X32.878 Y-53.112
    X31.852 Y-52.003
    X-53.061 Y32.844
    X-53.112 Y32.878
    X-53.213 Y32.893
    X-53.309 Y32.901
    G03 X-55.749 Y20.08 I33.949 J-13.104
    G01 X-55.659 Y-35.798
    G02 X-48.08 Y-38.131 I-4.373 J-27.69
    G02 X-39.731 Y-45.353 I-9.648 J-19.591
    G03 X-36.963 Y-45.935 I1.675 J1.093
    G00 Z5.
    X-52.739 Y-35.498
    Z-10.
    G01 Z-15.
    G03 X-51.533 Y-38.056 I1.882 J-0.676
    G02 X-42.866 Y-43.411 I-6.516 J-20.239
    G01 X-41.066 Y-45.546
    G02 X-37.262 Y-54.923 I-16.467 J-12.141
    G01 X-37.017 Y-56.253
    X-36.846 Y-56.591
    X-36.618 Y-56.801
    X-36.263 Y-56.945
    X20.094 Y-56.974
    G03 X33.931 Y-54.227 I-0.12 J36.831
    G03 X34.499 Y-53.258 I-0.38 J0.874
    G01 X34.398 Y-52.917
    X-52.676 Y34.229
    X-52.917 Y34.398
    X-53.258 Y34.499
    G03 X-54.082 Y34.162 I-0.097 J-0.937
    G01 X-54.428 Y33.494
    G03 X-56.974 Y20.094 I34.138 J-13.428
    G01 X-56.953 Y-36.176
    G03 X-56.399 Y-36.962 I0.948 J0.08
    G02 X-51.533 Y-38.056 I-3.586 J-27.317
    G03 X-48.975 Y-36.851 I0.676 J1.882
    G00 Z5.
    X20.355 Y34.444
    Z-10.
    G01 Z-15.
    G03 Y31.616 I1.414 J-1.414
    G01 X32.265 Y19.706
    X32.541 Y19.544
    X32.855 Y19.503
    X33.112 Y19.579
    X33.191 Y19.659
    X33.219 Y19.765
    G03 X32.12 Y21.564 I-2.178 J-0.095
    G02 X21.139 Y32.582 I26.584 J37.478
    G03 X19.777 Y33.207 I-1.388 J-1.228
    G01 X19.597 Y33.113
    X19.485 Y32.89
    X19.464 Y32.627
    X19.56 Y32.412
    G02 X19.929 Y30.336 I-1.273 J-1.297
    G01 X19.191 Y28.124
    G03 X19.719 Y25.888 I2.072 J-0.691
    G01 X36.773 Y8.834
    G03 X37.727 Y9.229 I0.395 J0.395
    G01 X37.718 Y21.97
    G03 X36.255 Y24.172 I-2.44 J-0.034
    G02 X23.82 Y36.807 I21.733 J33.826
    G03 X21.95 Y37.707 I-1.87 J-1.493
    G01 X9.25
    G03 X8.855 Y36.752 I0. J-0.559
    G01 X17.81 Y27.798
    G02 X18.337 Y25.562 I-1.545 J-1.545
    G01 X17.6 Y23.351
    G03 X18.128 Y21.115 I2.072 J-0.691
    G01 X41.281 Y-2.038
    G03 X42.235 Y-1.643 I0.395 J0.395
    G01 X42.216 Y24.621
    G03 X41.076 Y26.584 I-2.262 J-0.001
    G02 X26.397 Y41.334 I16.676 J31.274
    G03 X24.645 Y42.207 I-1.752 J-1.321
    G01 X-1.614
    G03 X-2.009 Y41.252 I0. J-0.559
    G01 X16.219 Y23.025
    G02 X16.746 Y20.789 I-1.545 J-1.545
    G01 X16.009 Y18.578
    G03 X16.537 Y16.342 I2.072 J-0.691
    G01 X45.79 Y-12.91
    G03 X46.743 Y-12.515 I0.395 J0.395
    G01 X46.713 Y27.585
    G03 X45.469 Y29.462 I-2.04 J-0.001
    G02 X29.268 Y45.791 I12.19 J28.296
    G03 X27.578 Y46.707 I-1.69 J-1.102
    G01 X-12.478
    G03 X-12.873 Y45.752 I0. J-0.559
    G01 X14.628 Y18.252
    G02 X15.155 Y16.016 I-1.545 J-1.545
    G01 X14.418 Y13.805
    G03 X14.946 Y11.569 I2.072 J-0.691
    G01 X49.956 Y-23.44
    G03 X51.072 Y-23.036 I0.463 J0.463
    G01 X51.249 Y-20.004
    X51.211 Y30.831
    G03 X49.939 Y32.566 I-1.82 J-0.001
    G02 X32.498 Y50.045 I7.812 J25.236
    G03 X30.836 Y51.207 I-1.662 J-0.608
    G01 X-21.199
    X-23.045 Y51.038
    G03 X-23.438 Y49.953 I0.058 J-0.634
    G01 X13.037 Y13.479
    G02 X13.564 Y11.243 I-1.545 J-1.545
    G01 X12.827 Y9.032
    G03 X13.355 Y6.797 I2.072 J-0.691
    G01 X53.061 Y-32.844
    X53.112 Y-32.878
    X53.213 Y-32.893
    X53.309 Y-32.901
    G03 X55.749 Y-20.08 I-33.949 J13.104
    G01 X55.659 Y35.798
    G02 X48.08 Y38.131 I4.373 J27.69
    G02 X36.804 Y51.366 I9.663 J19.653
    G02 X35.831 Y55.606 I28.03 J8.665
    G01 X35.813 Y55.648
    X34.389 Y55.707
    X-21.404
    G03 X-32.91 Y53.3 I1.433 J-35.562
    G01 X-32.897 Y53.209
    X-32.878 Y53.112
    X-31.852 Y52.003
    X12.4 Y7.751
    G03 X15.229 I1.414 J1.414
    G00 Z5.
    X-31.013 Y52.227
    Z-10.
    G01 Z-15.
    G03 Y49.398 I1.415 J-1.414
    G01 X52.227 Y-33.841
    G03 X53.258 Y-34.499 I1.67 J1.48
    G03 X54.082 Y-34.162 I0.097 J0.937
    G01 X54.428 Y-33.494
    G03 X56.932 Y-21.433 I-33.64 J13.275
    G01 X57. Y34.829
    X56.959 Y36.118
    G03 X56.399 Y36.962 I-0.959 J-0.028
    G02 X49.564 Y38.764 I3.681 J27.829
    G02 X37.262 Y54.923 I8.231 J19.029
    G01 X37.017 Y56.253
    X36.846 Y56.591
    X36.618 Y56.801
    X36.263 Y56.945
    X-20.094 Y56.974
    G03 X-33.931 Y54.227 I0.12 J-36.831
    G03 X-34.491 Y53.53 I0.488 J-0.965
    G01 X-34.493 Y53.191
    X-34.401 Y52.922
    X-33.841 Y52.227
    X-32.427 Y50.813
    X-31.013 Y49.398
    G03 X-28.184 I1.415 J1.415
    G00 Z5. S3500
    X-67.376 Y61.719
    Z-25.
    G01 Z-30.
    G41 X-73.74 Y55.355 D3
    G03 X-55.355 I9.192 J9.193
    G02 X-20. Y70. I35.355 J-35.355
    G01 X58.
    G02 X70. Y58. I0. J-12.
    G01 Y-20.
    G02 X20. Y-70. I-50. J0.
    G01 X-58.
    G02 X-70. Y-58. I0. J12.
    G01 Y20.
    G02 X-55.355 Y55.355 I50. J0.
    G03 Y73.74 I-9.193 J9.193
    G40 G01 X-61.719 Y67.376
    G00 Z5.
    M99
    N103
    G00 X-58. Y-58.
    Z5.
    G81 G98 X-58. Y-58. Z-34.554 R2. F100.
    X58. Y58.
    G00 G80 Z5.
    M99
    N104
    G00 X-58. Y-58.
    Z5.
    G82 G98 X-58. Y-58. Z-5. P.5 R2. F75.
    X58. Y58.
    G00 G80 Z5.
    M99
    N105
    G00 X-58. Y-58.
    Z5.
    X58. Y58.
    G00 G80 Z5.
    M99
    Jun 2008
    125
    Actually, having looked at the post again I might not get this done in my lunch hour.
    Give me a day or two and I'll make some good notes. It's not too complicated. Just a couple of variables, an ask box in the start code con, and a procedure in the misc whiteboard. The best best is in 'rapid after toolchange' where we have a switch which diverts the code into a sub program and 'rapid to toolchange' where the code is diverted back into the main program.
    Sep 2008
    24
    That sounds great. CodeWizard is not my strong side. My knowledge ends with creating a 3 axis Fanuc post.
    Variables, create an ask box... im blank. But if you tell me exactly what and where 2 add it, i think i can do it.
    I'm excited. but take your time. Thanks a lot Meegers !
    Jun 2008
    125
    I'll probably create a new post as I copy the ;code from the original. What version of Edgecam are you running and I'll write it in that, if I've got it. I've got 2012r1, 2013r1, 2013r2 and 2014r1.
    Sep 2008
    24
    2014 R1
    Jun 2008
    125
    I tried to create a new post but can't get it to work. Easier to reply to this ...
    Guys,
    As promised please find attached a post and a simple ppf. Have done this for 2014r1 but the logic in the post can be copied into older posts - have tested back to 2012r1 using an adaptive ISO mill template. Note that I've copied the coding from a customers post and placed into a brand new out-of-the-box template post which hasn't been tested so I may not have fully checked all aspects of this post. In other words - don't just run this post and expect it to work first time. It was based on a Haas if I remember correctly.
    Open the post with 2014r1 Code Wizard, compile it and we're ready to go!
    Basics.
    What this post/ppf will show is a simple method of programming a part and then outputting the code to multiple work offsets. Program assumes all these work offsets are pre-set although for those who know how, the post can be amended to output G10's too.
    The ppf is simple enough - just program a 3 axis part as usual. I've kept it simple - no need for datum shifts etc.
    When you're happy with the programming, then output the code and you'll get a pop up box asking you to select how many work offsets you want to output to. The post will then output a main program - which contains all setups, toolchanges and calls to subs. The post will also output another program containing all the subs rolled into one file. Then you can either copy the subs into the main, or if you have the skills write a PDI to append both progs together and select as a run-after PDI.
    Post Coding.
    Program Start Code Con - We have a variable setting and the coding for the ask box.
    Program End Code Con - Coding that outputs any sub routines into a sub program.
    Customisation Whiteboard - Declarion of two variable - and procedure which loops the number of work offsets.
    Rapid After Toolchange/Feed After Toolchange - Coding in here is the important bit. %OUTFILE will divert the following nc code into a seperate file, in this case set by $user5=Subs.nc
    Rapid to Toolchange/Rapid to Home - This then diverts the following nc code back into the main program - so all toolchanges are in the main. Here %OUTPUT=STANDARD is thr code that does that.
    Guys - have a look and let me know your thoughts!
    M
    Sep 2008
    24
    Very impressive Meegers. Although I never manage to make that pdi, this is awesome.
    Bye bye creating Cpls, rapid moves, Index Translate, all boring work is gone!
    Even Operations work with this.
    I can just say; thank you very much and hit the rep.button.
    Your awesome Meegers.
    Jun 2008
    125
    Re: Job setup for 2 or more vices in Edgecam
    No problem - forgot to add to earlier post that you'll need to set up some user variables in the format table - #user17 to #user20. Just copy the format from my post.
    Also, feel free to drop me a line if you've copied my post to one of yours but it doesn't work 100%.
    May 2004
    142
    There are a few ways of going about this. I use multi vises all the time. My favorite way of running the same part on multiple vises is to use Matrix mode... it is extremely easy... and does not require setup of g55 etc,
    you just need to know the separation distance from part to part.. Matrix mode does all the work of organizing the tool usage for you... and you just have to program it once. Matrix mode can be applied after you program the part or on use with existing ppf's... and it can be modified at any time.
    If you are using multiple ops in one ppf program (different parts)... then use datum shift.
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Sep 2008
    24
    When i have a Datum **** between Matrix Mode On and Off i get this:
    Invalid command within Matrix definition.
    Can you output G54 G55 G56 if you type 545556 in work datum override ?
    Or do you have to place your part 100% exactly on the table using the spacing from matrix (no Cpls)?
    Helix77 cant you post a simple example here using the Training Mill mm. mcp ?
    May 2004
    142
    No... you do not need to add any datum shifting. that's why its so easy... you don't need to use anything but g54 (provided that you are milling multiples of the same part)
    No need to post any sample code here.
  1. Gerardi Vices
    By brobones in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-11-2012, 06:30 PM
  2. Multiple vices
    By capmkrk in forum Mastercam
    Last Post: 05-30-2012, 11:03 AM
  3. Which of these vices is more rigid?
    By slashmaster in forum Benchtop Machines
    Last Post: 12-10-2010, 10:21 PM
  4. Cam Lock Vices
    By 2_many_hobbies in forum Benchtop Machines
    Last Post: 05-14-2010, 02:37 PM
  5. WHICH ONE OF THESE TWO VICES WOULD YOU BUY?
    By Oldmanandhistoy in forum Benchtop Machines
    Last Post: 04-14-2008, 08:14 PM
