585,728 active members*
4,139 visitors online*
Results 1 to 10 of 10
    Dec 2013
    47
    3D printed parts for CNC?
    Hello!
    I have a 3D printer and i wanna build a CNC.
    Would ABS printed parts be strong enough for a Z axis? With 20% Infiil?
    Any experiences?
    Oct 2010
    1189
    Depends what you want to cut i think Foam or Light Plastik May be possible but Try it and tell US
    Gesendet von meinem SM-N9005 mit Tapatalk
    Apr 2013
    97
    Quote Originally Posted by crimar View Post
    Hello!
    Any experiences?
    I would say no you need a lot of strength for cutting. I have designed and built 3-D printer and small CNC Mill lathe and router. The only thing that you be able to cut would be Styrofoam and even that wouldn't be that good
    Dec 2013
    47
    Okey.
    My plan was using plywwod for most of the CNC. Gantry, support and bed. Just print out parts for the CNC axis for the accuarcy it gives.
    I may print, then reinforce it with fiberglass and cut new parts for the Z axis out of plywood.
    Oct 2010
    317
    Why not 100% infill?
    Dec 2013
    47
    Because it will days to print the parts :/
    Oct 2010
    317
    You need a faster printer.
    Apr 2004
    5734
    This could work for some small router parts, if you printed them in PLA, then invested, burned out, and cast the parts in aluminum. But routers (that are any good, anyway) don't have any plastic parts that I can think of.
    Andrew Werby
    computersculpture "dot" com
    Oct 2010
    1189
    crimar i agree with awerby milling even wood will be complicated.
    So even if you have a lot of mechanical knowledge and calculate the perfect form of all the parts you need. i think it is not worth the efford. or try it and show us the result
    thomas
    Dec 2013
    47
    Okey.
    I did contact a local mechanical shop, but the prices they demanded for some simple aluminum pieces was sky high.
    I am gonna try print the parts and reinforce them with fiberglass, then the first cut will be a new parts with plywood.
  1. 3D printed gun parts discovered during police raid in UK
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 03-17-2015, 01:53 AM
  2. Finishing Off 3D Printed Parts - Objet
    By Mattyvdv in forum 3D Printer / 3D Scanner Discussion
    Last Post: 05-23-2014, 01:39 PM
  3. Here Comes The FUD: UK Police Claim To Find 3D-Printed Gun Parts In Raid On Home
    Last Post: 03-19-2014, 02:42 PM
  4. Need parts printed?
    By eaglezsoar in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-12-2012, 09:58 PM
