585,956 active members*
4,395 visitors online*
    Feb 2014
    Remote i/o error on mazak
    Hi guys! New on forum.
    Someone knows about the 55 Remote i/o error in a Mazak FH5800. The nc is a PC-FUSION 640.
    May be a communication error between one of the remote i/o cards and the nc, but this occurs ocasionally and probably will get worst.
    Someone have solved some error like this before?
    Thanks in advance!
    Feb 2011
    15
    Re: Remote i/o error on mazak
    Yes I am a service company in New Jersey Accurate Machine Repair. Definitely and I/O error. Found several issues in the past, chiller unit overheating sooo bad that the fan burned out the SSR on the remote I/O unit. Second issue found Z axis cover not sealing correctly and coolant getting into electrical Z axis box. Good Luck Carmine from Accurate Machine Repair 908-420-9509
  1. Mazak Vqc 20/40B error massage
    By evrgrecnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2012, 07:59 AM
  2. MAZAK R.D. Error
    By sjh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2011, 01:40 PM
  3. Need help Mazak Tap Cycle Error
    By Payhoe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2011, 02:33 PM
  4. Z09 remote IO error
    By otanica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-10-2010, 03:13 AM
  5. Mazak VTC20 error
    By ZipSnipe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-22-2006, 05:46 PM
