585,992 active members*
5,661 visitors online*
    Dec 2013
    setting up tool in vetric aspire
    newbie here, I have been learning the cad and cam software and have cut a few thing s out. I am to the point that the machine is doing what I thought it was going to do. up until now I have been using end mills and vcarve bits and have not had to enter any new tools into aspire. I just got a set of taper ball nose bits in and I need enter them as new tools. the following is the information provided by the bit manufacture:
    •Tool Type: Tapered Ball Nose
    •Shank Diameter = 0.250"
    •Half angle ◦0.0313in. (1/32in.) dia. tip - 6.2°
    ◦0.0625in. (1/16in.) dia. tip - 5.4°
    ◦0.1250in. (1/8in.) dia. tip - 3.6°
    ◦0.2498in. (1/4in.) dia. tip - 0.10°
    •Tip radius = nominal ±0.001"
    •Stepdown = Depth per Pass, use 2 X tip diameter for roughing (clearance) and 0.10 X tip diameter for final cleanup
    •Depth of Cut (DOC) = 1.074"
    •Stepover (for final cleanup pass) = 0.10 X tip diameter
    •Stepover (for roughing, clearance pass) = 0.25 to 0.40 X tip diameter
    •Spindle RPM (SPEED) = 5 KRPM to 60 KRPM
    •Feedrate (IPM) = Depends on the material being cut. Do the Sweetspot Test before setting this parameter
    (go to: Calibrating Feeds and Speeds with Carbide Microtools).
    •Plunge rate = 10 IPM to 25 IPM (again depending on material being cut)
    My problem is that the terminology is not 1-1 with aspire. if someone could teach me what information applies to what box in aspire I would appreciate it very much. here is a screen capture of the software:
    Select New Tool, then for Tool Type, select Tapered Ball Nose.
    Then you can enter the side angle and tip radius (3.2 and .03125 for the first one)
  1. Aspire drilling tool path in STL part
    By maly-miller in forum Aspire
    Last Post: 02-21-2014, 11:14 PM
  2. Aspire tool path calculation 40 + mins!
    By BOATDUDEGUY in forum Aspire
    Last Post: 08-25-2013, 12:23 AM
  3. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  4. Vectric Aspire Tool Info
    By stefon in forum Aspire
    Last Post: 09-21-2012, 10:23 PM
  5. Vetric or BobCAD-CAM v24 mill/BobART Pro?
    By reflectivist in forum Uncategorised CAM Discussion
    Last Post: 04-18-2012, 05:45 AM
