585,752 active members*
4,160 visitors online*
Thread: Pendent
Results 1 to 10 of 10
    Mar 2006
    113
    Pendent
    Anyone use a different pendent then the one sold by Flashcut? I would like a pendent with a dial and keys.
    Nov 2008
    12
    Re: Pendent
    I wish they supported the Contour Shuttle, I use them on all of my Mach3 machines and they work great.
    c
    Nov 2011
    15
    Re: Pendent
    I recently setup a Contour Shuttle Pro 2 on my flashcut controller. I use the wheel(s) for jogging Z, and use the buttons for jogging X,Y. I assigned other buttons for slow/med/fast jog rates, and others for continuous/.100/.01/.001 step increments. It's not a real pendent with mpg for all the axis, but its the best I could come up with. It's 10X better than trying to jog the machine using mouse/keyboard/touch screen.
    Overall, I'm very satisfied with my Flashcut control, but its disappointing that the pendant they sell is $400, and it doesn't even have a jog wheel. They are very clever people, they could easily setup a plugin like Mach for the shuttle pendant.
    Nov 2008
    12
    Re: Pendent
    xtwalt,
    What did you have to do to get this to work? What software did you install?
    cheers,
    c
    Nov 2009
    4415
    Re: Pendent
    He used the Shuttle Pro plug in.
    A lazy man does it twice.
    Mar 2006
    113
    Re: Pendent
    Where is the shuttle pro plug in located? Are you talking about the Mach3 plugin if so how do you install it in Flashcut?
    Nov 2011
    15
    Re: Pendent
    I used the setup software from Contour. I downloaded the Windows 8 version from their website, since the device I purchased from ebay is used and only came with XP drivers.
    I assigned keyboard strokes to the buttons / wheels to mimic using the keyboard (see the list below). I wish there was a way to use the wheel in combination with a button to also drive X and Y axis, but couldn't figure a way to do that with their software. This is where a smart programmer could easily write a custom Plug-In, like the Mach people did. Being able to Jog Z with the wheel is where I needed it most, for setting tool lengths and etc.
    • X AXIS + = CTRL + Right Arrow
    • X AXIS - = CTRL + Left Arrow
    • Y AXIS + = CTRL + Up Arrow
    • Y AXIS - = CTRL + Down Arrow
    • Z AXIS + = CTRL + Page Up
    • Z AXIS - = CTRL + Page Down
    • A AXIS + = CTRL + Plus (+) Key
    • A AXIS - = CTRL + Minus (-) Key
    • Fast Jog Speed = T
    • Medium Jog Speed = D
    • Slow Jog Speed = W
    • Contunous = O
    • 0.1 = O ~ Down Arrow
    • 0.01 = O ~ Down Arrow ~ Down Arrow
    • 0.001 = O ~ Down Arrow ~ Down Arrow ~ Down Arrow
    • Step = E
    Hope this helps. I would love to see if anyone else can figure out a way to make this better.
    Walt
    Mar 2006
    113
    Re: Pendent
    I can't get these keys to work, the only thing that happens is the Y axis moves. I was able to toggle a button for the rate - slow, medium, fast but can't figure out the keystroke for the jog distance .1, .01, .001
    Dan
    Nov 2011
    15
    Re: Pendent
    I played around some more and found a way to get the wheel to work for X,Y and Z. You have to make (3) different target applications and a button to switch between them. All are identical except for what is assigned to the jog wheel. I've attached a link to my Youtube Channel "WD CNC". This is easier than trying to explain it. I can email you the settings files for the shuttle pro if you email me.
    Here is the link:
    Flashcut CNC Pendant - YouTube
    It's not perfect, but good enough for now.
    Walt
    [email protected]
    Mar 2006
    113
    Re: Pendent
    Cool beans.
    Just a note. I could not get the jog distance to work using the down arrow. You need to have checked the "Keyboard Jog Requires Control Key" under the Jogging Settings menu.
  1. CNC4PC MPG pendent + C22 setup
    By happytriger2000 in forum Mach Software (ArtSoft software)
    Last Post: 05-02-2009, 03:46 PM
  2. DSP pendent -how it works?
    By Fonfon in forum Open Source Controller Boards
    Last Post: 02-28-2009, 08:06 PM
  3. cnc4pc pendent
    By davidponte in forum Mach Mill
    Last Post: 12-26-2008, 07:28 AM
  4. Tormach MPG Pendent and MACH3
    By Capteod in forum Mach Wizards, Macros, & Addons
    Last Post: 04-23-2008, 02:17 AM
  5. Pendent Control Finished
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-14-2007, 02:24 AM
