585,560 active members*
3,136 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need recommendation for drilling and tapping machine
    Mar 2014
    I`m looking for some recommendations and after searching for some time, I decided to make a post and ask for help..
    I`m looking for a small CNC 3-axis machine with the following requirements:
    0. must be at least 12x12x2 inches cutting area
    1. be able to cut pieces out of 0.25 inch thick polycarbonate sheet
    2. be able to drill 2.5mm holes in the polycarbonate
    3. be able to TAP M3 holes in the polycarbonate, meaning I need either a tapping head or just a robust spindle that also reverses.
    I`m looking for OUT OF THE BOX solution, preferrably with a reliable, free software available. I am looking at the fireball router tables but I can`t tell if you can change the heads on those to something that can actually tap holes.
    Jan 2010
    2141
    I don't have an answer for you, but I do have a related question (a friend of mine has a Fireball router table, and from memory it seems that the Z-axis capacity is far less than that of a typical milling machine or drill press).
    Does the Fireball actually have sufficient Z-axis height range and table clearance to accommodate a tapping head?
    Nov 2013
    10
    Topper or robodrill make small machines that will rigid tap.
  1. Replies: 0
    Last Post: 07-22-2013, 10:02 AM
  2. Replies: 0
    Last Post: 07-26-2011, 02:41 PM
  3. Doing some hand drilling and tapping into my machine.. advise fishing
    By photomankc in forum MetalWork Discussion
    Last Post: 04-29-2010, 04:12 PM
  4. DRILLING AND TAPPING MACHINE
    By JMECKES in forum MetalWork Discussion
    Last Post: 08-10-2009, 01:03 PM
  5. DRILLING AND TAPPING MACHINE
    By JMECKES in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2009, 03:10 PM
