585,557 active members*
3,333 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Help! Need Meistergram DOS software
Results 1 to 7 of 7
    Feb 2005
    Hi- Working on a Meistergram machine for a friend.... He's been using the old D.14 DOS software for it and has 1000's of jobs saved in that format, so he want to continue using. His old hard dive bit the dust & no backup disks.
    Anyone have have software they could email me?
    thanks!
    -John in WI
    Mar 2018
    Re: Help! Need Meistergram DOS software
    Just joined the group. I have an old Meistergram engraver I inherited from a prior teacher - do you still need the disks? I can make images and email them to you.
    Feb 2005
    Appreciate the offer. I did wind up finding some Meistergram software that worked.
    I've been meaning to upgrade that whole machine for my friend- Signlab or even Mach3 with Corel Draw, etc, but he's old school and actually prefers the old Meistergram stuff.
    Go figure.
    Thanks again
    Mar 2018
    Great - old software like that can be problematic at best. There are a few archive sites I've come across I like to check ( archive.org is one ).
    I'm looking into upgrading the machine as well. Currently running Engravelab 5 on a Windows XP laptop ( it won't run on anything later ) . I'm trying to figure out if the engraver controller speaks G-Code, or is it something proprietary.
    Feb 2005
    As far as I know it's not G-Code.... it's proprietary. I did try writing some "Meistergram" files from Signlab/Engravelab, but the controller wouldn't recognize them. You got that to work?
    I didn't try very hard to get it working, though. Might be some options I needed to change in the Cadlink meistergam.ini file for that machine. Also, the old 720K floppy disk system my friend uses was just not practical.
    I did look at the electronics in the box and it didn't look like much of a stretch to find the step & direction pins on the stepper controllers and just use Mach 3. Or new stepper controllers these days are cheap.... It's a nice sturdy machine that is worth saving. I did a similar retrofit on a Vision engraver that had a bad controller. Use it everyday.
    Oct 2016
    30
    Quote Originally Posted by jarable View Post
    You can use e machine in any Windows version. Windows 10, 8,7, WinXP. You need good software for this.
    I have the software that you need for this machine. Let me know if you are interested. [email protected]
    Mar 2018
    I bought a compact flash - IDE adapter and plugged it into the IDE port on the board. I made a power supply splitter from an old PC power supply so I now also have a 20 MB HDD on the engraver - boots much faster, and with a RAM upgrade from an old machine the bonus is I can now play DOOM on it.
    I connected another machine to Engrave Lab 5 serial output and captured the data. It looks a lot like G-Code ( lots of repeating patterns starting and sections ), but pretty sure it would take more time than I have to decode it all.
  1. Need software advice...What software can import .JPG files?
    By pairofjacks in forum Uncategorised CAM Discussion
    Last Post: 06-01-2011, 12:18 PM
  2. MIE Solutions - Free Quoting Software Trial Software available
    By MIE Solutions in forum News Announcements
    Last Post: 01-07-2009, 05:42 PM
  3. First post in the software dept. Free cnc software?
    By runinbymdnt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2007, 04:49 AM
