585,978 active members*
4,438 visitors online*
Results 1 to 14 of 14
    Oct 2007
    5
    Fanuc EDM Alpha-OC Reference Return
    Hi all,
    I am learning to use my recently acquired 1998 Fanuc Robocut Alpha-OC, and am stumped !!
    After having read the entire operators manual, I am still unable to zero the axes to get the system moving under program control.
    Please someone tell me how to do a reference return.
    All help is appreciated.
    Nov 2011
    13
    hi Frinkdaddy1
    check the maintenance manual Sect II Part 7 "setting the machine zero point"
    Oct 2007
    5
    Thank you sir, that's exactly what I did last night. Apparently the servo pulse coders lost power at some point in time and forgot the reference point coordinates.
    I should have the machine up and running tonight. Initially when I thought reference return, I was thinking Fanuc OT and was looking for a (ref) button to push.
    Regards,
    F1
    Oct 2010
    9
    Re: Fanuc EDM Alpha-OC Reference Return
    Quote Originally Posted by frinkdaddy1 View Post
    Regards,
    F1
    I'm assuming you figured this out, but I have a printout I got from Methods Machine that gives step by step directions on how to do the reference return. If this would help anyone out I can scan them and upload.
    Oct 2007
    5
    Hello wdevine,
    I did finally figure it out, after reading the Fanuc manual about twenty times.
    It seems that something is lost in the translation from Japanese to English.
    I would be very interested in Methods' translation, just for my own records.
    F1
    Oct 2010
    9
    Ask, and ye shall receive. PDF should be attached.
    Attached Thumbnails Attached Thumbnails FANUC HOME SET.PDF
    Oct 2007
    5
    Fantastic,
    So much easier to understand.
    Thanks so much.
    Jul 2015
    Dear frinkdaddy1!
    What diameter is the adjustment nozzle? I read the Method document, and i don't see the diameter of the adjustment nozzle.
    tibi1
    Feb 2020
    Hello,
    I've made a mistake and I set the machine coordinate in the lowest point and now i cannot move it on Z+. How I can change the absolute coordinate to 0?
    Oct 2020
    4
    Quote Originally Posted by wdevine View Post
    Thanks wdevine, without people like you,life would be harder than it is ,Thanks
    Oct 2020
    4
    Hi wdevine, I am trying to reset the taper angle as it is 1.2 deg out, I can take the measurement to the bottom guide, but am unsure how I can calculate the top guide settings, have you any idea about these settings,
    Thanks ,
    Angusmac2
    Oct 2020
    4
    Hi theblackwatch, have you any idea as how to set the taper data as the machine is 1.2deg out,
    thanks
    Angusmac2
    Nov 2011
    13
    Hi Angusmac2
    I would check the parallelism of the upper and lower guides
    see maintenance manual. routine maintenance sect, 2.4.4
    also recheck Verticality of wire adjustment sect,2.2.2
    Regards
    theblackwatch
    there is a maintenance function in EDM to set wire alignment. There is a tool (wire alignment block) that should be supplied with each machine. Instructions are in manual and machines on how to perform the wire alignment. This is recommended to be done every 30 days.
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Adjust Reference Position Return - 10M
    By Swemill in forum Fanuc
    Last Post: 09-28-2011, 04:03 AM
  3. Reference return incomplete
    By Leha_Blin in forum Fanuc
    Last Post: 08-17-2011, 04:22 AM
  4. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
