I agree with Jerry, I have three Kress 800-FME spindles! When running at MAX RPM, the brushes wear out really fast! So I just swap spindles and keep cutting, while I replace the brushes in the other spindle!
As for speeds & feeds, charts are conservative to say the least! Every machine has its strengths & weaknesses, so I usually push it to the limit and back it off at the optimal point! This is a good practice if you are producing more than one part, as you can make adjustment to get the run perfect! But one-off parts require a little more patience and feel for how the machine is vibrating and sounding while cutting!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
