Hi all. So I am preparing to convert a G0704 mill to CNC. I don't have any machining or CNC experience so this will be an adventure! I have lots of questions and this is more of a blanket post. I am trying to understand more about what all I will need to get started. I already purchased the 3 axis electronics package from Keling that Hoss recommended. My plan is to buy all the tooling, raw material and software/electronics I will need to do the conversion before I buy the machine. That way when the mill comes in I hope to be ready to get started. I will be buying Hoss’s DVD here shortly and am not asking for information contained within it. He has a list of all the end mills, taps and other misc. items that will be needed for the conversion on one of his web pages. So with that being where I’m at right now. Here are my questions for now.
What is the best setup for tool holding? I have seen a few post’s regarding TTS collet type tool holding. I do plan on doing a PDB if that makes a difference.
I have Autodesk Inventor 2014 and InventorCam. I plan on buying Mach3 too. I have a PC that I never use that runs Vista Home premium and I went to the ArtSoft forum and looks like this will work with a patch. Will I need anything else for now?
What is the preferred setup for the limit switches and homing switches? The limit switches can be used as the homing switches from what I have gathered. Is that correct and is there a better cost effective way?
Any other insight's you would like to provide to a beginner would be great too!
Thank you for any help and input!
