585,951 active members*
4,332 visitors online*
Results 1 to 15 of 15
    Sep 2007
    133
    Haas UMC -750
    hi, does anyone here work on Haas UMC-750 vertical 5 axis machine?
    wonder what the limitations of the machine and how its compared to equilivat of its class..
    what sort of things we need to look for? or ask if we buy the machine?
    is 12000 rpm ok for ali on that machine?
    regards.
    Sep 2007
    133
    So let me get this straight?, no one here works on HAAS UMC-750? wow..
    Mar 2010
    1852
    Unlike a simple VF-2 or something, there are not thousands of UMC-750s in the field. The actual odds of finding a user here are slim. Be patient and someone may show.
    Cheers---Mike
    Oct 2012
    23
    We got our UMC-750 installed 2 weeks ago. Its the first 5-axis machine i run, so i have little to compare with. My impression is that its pretty ridgid and a very nice machine.
    Skickat från min Nexus 5 via Tapatalk
    Sep 2007
    133
    Re: Haas UMC -750
    cool, what cam do you use to program it?
    Oct 2012
    23
    Re: Haas UMC -750
    We are using Gibbscam 2012+.
    Sep 2007
    133
    Re: Haas UMC -750
    does gibbscam fully functional with the machine? doesnt it do what it ment to do? have you tried High speed machining options?
    Oct 2012
    23
    Re: Haas UMC -750
    Yes i think it does the work well. I've tried 3+2 and full 5axis milling and it works. Haven't tried highspeed yet.
    The post processor we got from our swedish reseller still need some work to function good though. It put out some strange codes sometimes.
    Sep 2007
    133
    Re: Haas UMC -750
    Cool, I have heared that Haas are a bit light from one of our supplieers in New zealand..but i am not sure what that means..
    and I heared that they need alot of maintenance after 5 years of full work..not sure if that is true to the UMC-750 ..
    Aug 2010
    7
    Re: Haas UMC -750
    Hi, we will be receiving our new HAAS UMC-750 on Thursday and be installed on Friday, cant wait.
    We also work with GibbsCAM and find it a really awesome package, I myself started with Gibbs in 2009 and have never looked back to any other Cam packages.
    Nov 2014
    12
    Re: Haas UMC -750
    Any chance to get proper post processors for Vericut or Edgecam or SolidCAM for Haas UMC-750 somewhere? Thank you!
    Aug 2004
    780
    Re: Haas UMC -750
    The HAAS is light and cheap.
    Few machines in the class ...
    The competition is much more expensive, but heavier.
    And, a normal VMC is much more rigid.
    But you knew that, right ?
    All the Haas machines I know of/knew of (about 700+), work fine in all materials over the years.
    If the customer expectations are reasonable, so are the results.
    Avg customer satisfaction is 9+/10.
    A 5 axis haas is not the right choice for removing massive amounts of material quickly- but you probably knew that ?
    For much more money, you get faster material removal.
    You need to decide if it matters, in your use.
    Nov 2014
    12
    Re: Haas UMC -750
    Any chance to get somewhere proper post processors for Vericut or Edgecam or SolidCAM for Haas UMC-750? Thank you!
    Nov 2014
    12
    Re: Haas UMC -750
    I failed to find post processor for other CAM software out there, so tend to try GibbsCAM. Anyone could help me with Haas UMC-750 post processor for GibbsCAM ?
    Sep 2007
    133
    Re: Haas UMC -750
    Quote Originally Posted by hanermo View Post
    and why not? IF its Ridgid enough and use performance cutters and Volumill Syle cuts, then I dont see why it would not cut fast...
    a 5 axis can behave like a 3 axis except got 2 more axis..right?
  1. Replies: 4
    Last Post: 06-28-2013, 02:00 PM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. RFQ haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Employment Opportunity
    Last Post: 10-28-2009, 08:17 PM
  4. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
