So I was machining some angles into some 2x4 inch 1/4 wall steel tubing and had a 1 inch HSS 4 flute catch near the end of a cut and break. Ever since I've had a different noise when the spindle is running. The machine in question is an 06 vmx30 with a 10k spindle. I suspect the belt but perhaps someone can direct me otherwise. Really hoping I didn't mess up the spindle itself. I have measured with an indicator for play and haven't found any. But it was a very violent breakage as I'm sure you can guess. Shifted the vice 40 thou and the part in the vice shifted as well. Any advice is welcome of course.
