586,011 active members*
5,085 visitors online*
    Nov 2009
    11
    Connected-disconnected loop
    hi,
    because Cam software requirements I just migrated from WinXP to Win7Pro/32. With WinXP everything was working fine, now, with Win7 I can see that Kflop is always disconnected (from Kmotion window) and when I launch Mach3 or KmotionCNC a "connected-disconected" neverending loop start.
    What can I do?
    Nov 2009
    11
    I have solved!
    on my Win "device manager" kflop appeared as an unknown device, I have manualy installed kflop driver from KMotion folder and now it's fully working.
    I'd be curious to know why the kmotion installer did not install the kflop driver: does anyone have any idea?
    May 2006
    4045
    Hi geppo,
    Not sure why the connect-disconnect loop occurred. But the KMotion Installation doesn't actually install the device driver. The Windows New Hardware Found Wizard should do that. It might be there was one of our old drivers installed that was not Windows 7 compatible.
    Regards
    TK
    http://dynomotion.com
  1. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  2. CNC conversion typically open loop or closed loop?
    By foobar42 in forum Benchtop Machines
    Last Post: 10-30-2009, 01:21 AM
  3. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  4. tacho generator disconnected
    By scr in forum DNC Problems and Solutions
    Last Post: 07-16-2007, 04:28 PM
  5. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
