Hello everyone,
first of all, I apologize if a similar topic already exists. I looked for anything resembling my question to the best of my ability, but could not find anything.
As far as I understand, what I am trying to do is not a traditional solution. So much so, that I'm not even sure how the actual machining process is called in English. I think it is referred to as planing (when machining a flat surface) or shaping (when machining various grooves). A tool, somewhat similar to a turning (lathe) tool, is dragged along the surface of a workpiece in a linear motion, removing material as it goes along. The tool does not spin. It just cuts the the steel. A sort of straight line version of turning if you will. Shaving some material off of the surface, a couple of millimeters with every pass. Alternatively, the tool remains stationary and the workpiece moves. They used to do this to form large planes, as well as various grooves in flat surfaces. This process used to be commonplace a long time ago, but it has since been replaced by milling. I hope my attempt at describing this operation is sufficiently clear. If not, let me know and I will do my best to clarify.
What I'm trying to do, is to use a traditional, modern cnc mill to perform the operation described above, to cut some (relatively) tiny, but long grooves into a steel plate. I have already found some old theory books with speed and feed recommendations and other tips. I know the forces that would act on the spindle and I'm sure it will not do any damage to the machine. Also, I found the required tools and adapters to do the job. Just one problem remains to be solved, and I'm hoping someone here might have done something similar, or will have some ideas.
The tool to be used is going to be either a regular turning tool or a parting tool with removable inserts (fitted into the spindle via an adapter). For this to work, the tool (and thus, the spindle) has to remain static, in other words- it does not turn during the actual machining phase. The horizontal feed is the motion that cuts. Also, and this is the tricky bit, the tool must always be facing precisely forward, so as to make a proper cut. If the tool is misaligned, i.e. facing slightly sideways, the groove will be cut asymmetrically and, probably, otherwise flawed, not to mention the wear of the tool. I should probably mention at this point that this would not be a one-time-only experiment. It would be done repeatedly, over a small sized production run.
I guess what I'm trying to find out is if such a thing is at all doable? Has anyone ever tried such a thing? I imagine that the tool could be aligned manually the first time round, but it would be too time consuming to align it manually every time the operation needs to be carried out. Is it even possible to align the tool sufficiently accurately by hand? I think not.
I realize there are other options, but this is an interesting solution that has the potential to save considerable amounts of time, when machining long, thin, straight, repeating grooves.
