585,931 active members*
3,650 visitors online*
Results 1 to 13 of 13
    Jul 2013
    8
    Question Servo problem after battery change
    Hello,
    I really hope that you can help me.
    We are using CNC Brother TC-31A, after the "Low battery" icon appeared, we have replaced the batteries with new ones, but then a new error appeared:
    5066. 17 **M SERVO (BATT DROP)
    Below I've written all info found in operation manual on the 5066 error message
    Error message: M SERVO (***)
    Stop level 5: The servo system stops
    Reset level 3: Turn OFF the power. (An alarm cannot be reset otherwise)
    Cause: A servo error has occurred for the M axis. The cause differs depending on (***). Refer to the servo error list.
    SERVO ERROR MESSAGE
    Display: BATT DROP
    Cause: Battery voltage drop
    Solution: Replace alkaline battery for absolute encoder backup
    Already tried multiple times to turn off the CNC, put the old batteries back, but nothing helps.
    Have no idea how to fix that, it seems like no information is available via internet, that is why I think your experience could be appreciated very highly.
    Thank you in advance,
    Artur
    Jul 2013
    8
    Re: Servo problem after battery change
    I've got a reply to the question elsewhere, decided to post it here also, just in case anyone else is searching for the solution.
    Good afternoon Mr. Andrejev
    I guess the voltage of the backup batteries was cut for longer than 20-30 minutes.
    In this case the machine 'forgot' the magazine position and you need to set it again.
    Attachment 236518
    - After clearing the start point data, move the magazine position nr.1 to the tool change area and clear the start point once again.
    - Finally disable the ATC maintenance mode (I/O), (1), (Enter), (page up) set 0 for (ATC maintenance mode) and power the machine off and on again.
    - If everything went well you can start to work with the machine as usual.
    Kind regards / Mit freundlichen Gruessen
    Thorsten Schrodt
    Technical Support
    Nomura Trading Co., Ltd.
    Aug 2008
    6
    Hello.
    I have the same problem in Brother TC-31A. Link for attachment is invalid. Can you help me?
    Regards
    Grzegorz Szczepanski
    Sep 2017
    Quote Originally Posted by gelos73 View Post
    Hello.
    Regards
    From the Brother TC-31A & Brother TC-22A Maintenance manual page 9.1.16-1E (printed in 1999)
    Adjust the magazine position in ATC maintenance mode.
    1. Press [MANU] or [MDI],and then[I/O].
    2. Press[1],[ENT]and[PAGEDOWN].
    3. Press [CURSOR DOWN]until[ATC MAINT.MD]is highlighted and then press [1]and[ENT].
    4. Turn the <Power> switch off and then ON again.
    5. Press[1] for [CLEAR START P DATA].
    6. Turn the <Power>switch off and then on agian if [CLEAR START P DATA]displays [0].
    7. At this time, the pot No.of the ATC postion continues from [11] in case of No.1.
    8. In the case except No.1, it press [MAGZ] pot of the ATC position turns over to the ATC position at the pot of No.1.
    9. Press [1]for [CLEAR START P DATA].
    10. Turn the <Power> switch off and then on again if [CLEAR START P DATA] displays [0].
    11. Press [MANU]or [MDI], and then [I/0].
    12. Press [1] [ENT]and [PAGE UP].
    13. Press [CURSOR DOWN]until [ATC MAINT.MD]is highlighted, and then press [1]and [ENT].
    14. Turn the <Power> switch off and then on again.
    Jun 2018
    20
    brother tc32 bn ft
    hello do you have service manual or parameter manual for brother cnc interface unit?
    have problems with installing 2007 model brother tc32-bn ft
    5 axis
    If so, can you send it to [email protected]?
    Jun 2018
    20
    I can help for Brother cnc 5 axis BNFT series and tapping center.,
    [email protected]
    whatsapp number:+905357221418
    Mar 2022
    Quote Originally Posted by Andartur View Post
    Attachment 236518 spider solitaire
    Thorsten Schrodt
    Technical Support
    Hello, do you have a service manual or parameter guide for the brother cnc inter unit? Have problems installing 2007 model brother Tc32-bn Ft
    Nov 2020
    Hi, i had the same battery issue on a TC32A this morning.
    I changed batteries and i followed the steps to recover the alarm and it worked.
    Unfortunately now i have the tool position shifted by 3 or 4 degrees for every position.
    I didn't try to do a tool change because i'm afraid that the arm wil collide...
    How can i solve this?
    Thank you if you can help me
    Jan 2018
    1516
    Quote Originally Posted by Fauz View Post
    Could be servo indexing or homing position have shifted and need adjusting.
    Nov 2020
    Quote Originally Posted by dazp1976 View Post
    I think so. How could it be done? I can't find it on my manual
    15362
    You must change the Battery with the power on, its always best to home the machine (any machine) and then change the Battery you will have to check with the manufacture to see how to correct the out of position, they will have a recovery procedure
    Mactec54
    i am getting error like this in One of brother CNC , I changed the back up battery last month, and after getting this error we tried to changed it today but still has a same errors , any help would be appreciated.
    Jun 2018
    20
    Quote Originally Posted by dhavalpatel811 View Post
    please contact me whatsapp number +905357221418
  1. Battery change OSP7000L
    By bengt65 in forum Okuma
    Last Post: 06-17-2014, 03:31 PM
  2. Battery change resolved into problem
    By Andartur in forum Hyundai Kia
    Last Post: 05-20-2014, 06:57 AM
  3. Replies: 0
    Last Post: 08-23-2013, 02:38 AM
  4. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  5. Change Battery on Maho 600E, Phillips 432
    By Konrad in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-16-2010, 04:28 AM
