585,604 active members*
3,371 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Arduino Sherline Rotary Table controller
Page 3 of 5 12345
Results 41 to 60 of 86
  1. #41
    Nov 2011
    8
    Re: Arduino Sherline Rotary Table controller
    here is the latest .
    what version was it written in?
    i will try older version tomorrow. thanksClick image for larger version.
  2. #42
    Jan 2014
    57
    It was written in version 1.6.3
  3. #43
    Sep 2009
    1856
    change LCD.init to LCD.begin just make sure you have the Arduino-LiquidCrystal-I2C-library-master file set up how it say`s in the read me and keypad in the same place
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  4. #44
    Nov 2011
    8
    it compiles using 1.6.3 and uploads but nothing on lcd
  5. #45
    Sep 2009
    1856
    try uploading a lcd.12c example and see what happens
    [SIGPIC][/SIGPIC]
  6. #46
    Jan 2014
    57
    Tonight I will download 1.6.5 version, run the sketch and report back. Bob
  7. #47
    Sep 2009
    1856
    it compiles on 1.65
    [SIGPIC][/SIGPIC]
  8. #48
    Jan 2014
    57
    I downloaded 1.6.5 and the sketch compiled ok with no errors. Bob
  9. #49
    Nov 2011
    8
    there was no example lcd.i2c in folder. i ran hello world it ran ok, other examples with cursor blink no blink ok. just for the hell of it i plugged in 16x2 display key shield it is running on that display . thanks headed out this weekend to brother inlaw. He knows code for arduino. he is going to help figure it out. i will report back with the findings. thanks for all the help!!! I really appreciate
    it.
  10. #50
    Sep 2009
    1856
    put the files in this zip into C:\Users\your use file name\Documents\Arduino\libraries
    [SIGPIC][/SIGPIC]
  11. #51
    Mar 2009
    9
    **UPDATE**
    Almost 2 years ago I started this thread and I thought that I should probably share the final version of my rotary table controller. Here are some pictures of my completed enclosure. I added a divisions mode and setup the interface to allow the user to select between divisions or to enter the degrees directly a while back but others have added even more. To do it over again I would make a metal case for the controller because the 3D printed one is too flimsy to live in a shop for very long.
    Attachment 299772Attachment 299774
  12. #52
    Mar 2009
    9
    Updated my original sketch to work with the Libraries available for download in this thread.
    HTML Code:
    A program for controlling a single stepper motor driving a rotary table.
    Uses a 4x4 matrix keypad for entry of degrees and direction or number of divisions to move the table.
    Serial I2C display, Pololu stepper driver.
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    #include <Keypad.h>
    const byte ROWS = 4;
    const byte COLS = 4;
    char keys[ROWS][COLS] = {
      {'1','2','3','A'},
      {'4','5','6','B'},
      {'7','8','9','C'},
      {'.','0','#','D'}
    byte rowPINS[ROWS] = {11,10,9,8};
    byte colPINS[COLS] = {7,6,5,4};
    Keypad kpd = Keypad(makeKeymap(keys),rowPINS,colPINS, ROWS, COLS);
    LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x20 for a 16 chars and 2 line display
     //setup vars
    const int stp = 12;  //connect pin 12 to step
    const int dir = 13;  // connect pin 13 to dir
    const int StepsPerRotation = 400; //Set Steps per rotation of stepper
    const int TableRatio = 72; //ratio of rotary table
    const int Multiplier = (StepsPerRotation * TableRatio)/360;
    const int stepdelay = 1;
    float Degrees = 0;                //Degrees from Serial input
    float ToMove = 0;                 //Steps to move
    float Divisions;
    float current = 0;
    int Mode = 0;
    void setup()
      lcd.begin();                      // initialize the lcd
      pinMode(stp, OUTPUT);
      pinMode(dir, OUTPUT);
      // Print welcome message to the LCD.
      lcd.backlight();
      lcd.print("Rotary Table Control");
      lcd.setCursor(0,2);
      lcd.print("  CrankyTechGuy CNC");
      lcd.setCursor(0,3);
      lcd.print("   Copyright 2014");
      delay(2000);
      lcd.begin();
      Mode = GetMode();
    void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
    asm volatile ("  jmp 0");
    void rotation(float tm, int d)
      if(d == 0)
        digitalWrite(dir, LOW);
      else
        digitalWrite(dir, HIGH);
      for(int i = 0; i < tm; i++)
        digitalWrite(stp, HIGH);
        delay(stepdelay);
        digitalWrite(stp, LOW);
        delay(stepdelay);
    float GetNumber()
       float num = 0.00;
       float decimal = 0.00;
       float decnum = 0.00;
       int counter = 0;
       char key = kpd.getKey();
       lcd.setCursor(0,0);lcd.print("Enter degrees then");lcd.setCursor(0,1);lcd.print("    press [#].");
       lcd.setCursor(0,3);lcd.print("Reset [D]");
       lcd.setCursor(8,2);
       bool decOffset = false;
       while(key != '#')
          switch (key)
             case NO_KEY:
                break;
             case '.':
               if(!decOffset)
                 decOffset = true;
                lcd.print(key);
                break;
             case '0': case '1': case '2': case '3': case '4':
             case '5': case '6': case '7': case '8': case '9':
               if(!decOffset)
                num = num * 10 + (key - '0');
                lcd.print(key);
               else if((decOffset) && (counter <= 1))
                lcd.print(key);
                counter++;
               break;
             case 'D':
               software_Reset();
             break;
          decnum = num / pow(10, counter);
          key = kpd.getKey();
      return decnum;
    float GetDivisions()
       float num = 0.00;
       lcd.clear();
       lcd.setCursor(0,0);lcd.print("Enter Divisions then");lcd.setCursor(0,1);lcd.print("     press [#].");
       lcd.setCursor(8,2);
       while(key != '#')
          switch (key)
             case NO_KEY:
                break;
                lcd.print(key);
                break;
            case 'D':
              software_Reset();
              break;
          key = kpd.getKey();
         // num = 360/num;
      return num;
    int GetMode()
      int mode = 0;
      lcd.setCursor(0,1);lcd.print("Select Op Mode");
      lcd.setCursor(0,3);
      lcd.print("    DIV[A] DEG[B]");
      while(mode == 0)
      if(key == 'A')
        mode = 1;
      else if(key == 'B')
        mode = 2;
    lcd.clear();
    return mode;
    void loop()
      if(Mode == 1)
        Divisions = GetDivisions();
        Degrees = (360/Divisions);
      if(Mode == 2)
        Degrees = GetNumber();
        lcd.clear();
        lcd.setCursor(0,3);
        lcd.print("FWD[A] REV[B] CAN[C]");
        while(key != 'C')
          lcd.setCursor(0,0);lcd.print("POS:");lcd.print(current);lcd.setCursor(0,1);lcd.print("DPM:");lcd.print(Degrees);
          key = kpd.getKey();
          if(key == 'A')
           if(current >= 360)
             current = (current + Degrees)-360;
           } else {
           current = current + Degrees;
           ToMove = Degrees*Multiplier;
           lcd.setCursor(0,2);
           lcd.print("       Moving       ");
           rotation(ToMove,2);
           lcd.setCursor(0,2);lcd.print("                    ");
           lcd.setCursor(4,0);lcd.print("      ");
          if(key == 'B')
           if(current <= 0)
             current = 360+(current - Degrees);
           } else {
           current = current - Degrees;
           lcd.setCursor(0,2);
           rotation(ToMove,0);
         lcd.clear();
  13. #53
    Sep 2009
    1856
    that was close I was just about to post the mistake
    [SIGPIC][/SIGPIC]
  14. #54
    Dec 2015
    What is wrong ......
    Arduino: 1.6.5 (Windows 7), Board:"Arduino/Genuino Uno"
    rotary.ino: In function 'void setup()':
    rotary:45: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
    rotary.ino:45:13: note: candidate is:
    In file included from rotary.ino:10:0:
    C:\Program Files (x86)\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:59:8: note: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
    void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
    C:\Program Files (x86)\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:59:8: note: candidate expects 3 arguments, 0 provided
    rotary:57: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
    rotary.ino:57:13: note: candidate is:
  15. #55
    Sep 2009
    1856
    you don't have the 12c library it's in the zip in post 50 all 3 required libraries are there
    [SIGPIC][/SIGPIC]
  16. #56
    Dec 2015
    Thanks... It is working
  17. #57
    Nov 2010
    19
    thanks for documenting your build its awesome and Im going to have a go at making one.
  18. #58
    Mar 2012
    192
    Thanks for sharing. I made one too a couple years ago. Haven't used it in a while so this is inspiring me to dig it out and remember what I did. I used a 2x16 LCD and programmed it for number of steps (holes or gears) and angle step size, and free run/jog either direction with speed setting.
  19. #59
    Nov 2010
    19
    Hi, can I ask what pin numbers do the LCD screen connect to?, I think Im Ok with the rest of project, Just ordered the LCD screen and keypad. Ive got an arduino uno
  20. #60
    Nov 2011
    8
    i used a Serial I2C 1602 16×2 Character LCD Module it sits on the back of the display. it frees up pins for the keypad.
    [URL=".geeetech.com/wiki/index.php/Serial_I2C_1602_16×2_Character_LCD_Module" i went to a 4x20 display and a arduino nano for space.
Page 3 of 5 12345
  1. G1049 Rotary Table Versus Sherline set up
    By rkernell in forum Benchtop Machines
    Last Post: 08-21-2010, 03:31 AM
  2. Sherline rotary table threading
    By MechanoMan in forum Benchtop Machines
    Last Post: 07-08-2009, 11:23 PM
  3. Adapter for Sherline rotary table
    By diamondback21 in forum Taig Mills / Lathes
    Last Post: 04-13-2009, 11:26 AM
  4. Sherline CNC rotary table adaptation
    By uptoolateman in forum Benchtop Machines
    Last Post: 02-06-2009, 09:48 PM
  5. SHERLINE rotary table
    By ACME in forum Benchtop Machines
    Last Post: 11-17-2004, 05:15 AM
