Machine:
2004 Fryer MC-60 VMC with Anilam 6000 touch Controller
Symptom:
The Y axis loses about .020" after making a single circle interpolation.
Frequency of Issue:
I ran a large test 20" spiral style pocket with a 3/8" endmill to see if the position offset would be greater, and it was not, still about .020".
It seems that it loses about .020" with each program run.
Detail:
I have a vacuum table set as my fixture with the center of the vacuum table as my (G53O01) fixture offset.
If I set my offsets to the center of the vacuum table, home the machine, then move to X0Y0 (center of table), the mill returns to the correct center location.
Then if I make a circle motion of any radius, then return to X0Y0 the Y-axis is about minus .020" from the center of the vacuum table.
If I make another circle motion and return to X0Y0 the Y-axis is about minus .040" from the center of the vacuum table. So on and so forth.
This machine hasn't had any issues in the 5 years that I have had it. This problem started a couple days ago and has been doing it since.
My Theory:
My original thought is an encoder issue.
There is a linear encoder on the Y-axis, which originally I thought was causing the problem.
I went into the Setting Option to disable the linear encoder to find that it wasn't enabled.
I then enabled the Y-axis linear encoder, restarted the unit and homed the machine.
The Y-axis now homes to a different position.
The Y-axis machine zero is now about 3" less than it was before enabling the linear encoder.
I then set the New Offsets of the vacuum table, re-homed and made a move to fixture center X0Y0. The machine moved to the correct position.
I ran a program, and returned to fixture center and the Y-axis was off again by .020".
My understanding is that the purpose of having a linear encoder and servo mounted rotary encoder on a single axis is to account for any axis discrepancy. ie Backlash.
I'm now assuming that the rotary encoder may be at fault.
I contacted Fryer to inquire about a new rotary encoder, this is not an option, a whole servo motor must be purchased with the encoder.
I don't have an issue with spending the money to get this machine running correctly, but with not being 100% sure of the issue, I write you this long novel
of a post to get another opinion from someone who may have some experience with this issue.
Thanks in advance.
UPDATE: SOLVED
Turned on Backlash Compensation for the Y-Axis, and set the value at .0012".
Works like it should, I will take care of the backlash at a later date.
