I am finally getting around to documenting my 5’ x 10’ Bulltear plasma table with tube cutting area build.
There is 64” x 124” sheet cutting area and a 12” trough area to one side for tube cutting. This way I should not have to interrupt the flat plate cutting area when I need to cut some tubing. There is clearance for up to a 17” diameter tube. I have yet to design the tubing tail supports.
The following renderings show how the table was designed with as built updates.
Attachment 229020
This view shows the display/keyboard/mouse cabinet on a rotating arm. There is a 186-gallon water storage tank and table control cabinet behind aluminum side panels.
Attachment 229022
This view shows the slide out tray for the Hypertherm 85 on the side and the support and opening for a three-drawer cabinet. Also shown is the rotary axis.
Attachment 229024
The upper frame is 3/16” thk 3” x 5” tubing. The legs and under table laterals are 1/8” thk 4” x 4” tubing. The lower laterals are 1/8” thk 2” x 3” tubing. The 5” deep water tray is 12 gauge along with the water tank, and rotary trough. There are two fork truck tubes under table made with 3” x 5” tubing laid flat.
