For about a year now we've been having problems with our Z axis on a Kval CNC machine (Edge STS). This machine is basically a router for the "style" of wood doors. The Z axis drives the spindle in towards the product. It's really hit or miss for the overspeed error (no consistencies to it what so ever). Sometimes it happens 20 times in an eight hour shift, and every once in a while it'll go a month without problems.
The drive is a Lenze E94R040Y2NRX and the servo is a Parker MPM892BSG7G1N.
Things I've don to try and resolve the problem:
-Replaced the drive twice
-Replaced the servo
-Replaced the ball screw and nut
-Made sure the ball rail bearings associated with the Z axis are in good shape
-Reduced the weight of the head unit by at least 40+ lbs
-Ran auxiliary encoder cable
When we get this error, it's not usually under much of a load. I'll kill the machine to reset the drive, and there doesn't seem to be any mechanical issues upon inspection. It doesn't error out in the same spot at any time.
Do you guys have any ideas as to what would cause this problem? It's been going on for too long, and we've lost TONS of hours to it. Not to mention the ass-o-nine amount of money we've thrown at it.
Any ideas and opinions will be very much appreciated!
Regards,
Chris Denny
