Hello,
I have borrowed a DIY CNC 3 axis mill (small engraver). Man who built it (mechanically) doesn't have the configuration file anymore, and doesn't remember when was the last time he used it, or how he configured it, but it was definitely controlled by EMC2, and worked.
The stepper driver board is home made, so I cant use properties of existing boards in conf wizard, and I don't have any documentation about the driver...
I presume, who ever made the driver, used some guide... Here is a picture, maybe someone can recognize where did the design come from? Or the name of the driver?
When I plug parallel port, and power the machine, all axes get stiff, I cant move them by hand, so it should mean that the thing is working, mechanically. But, I can't configure it, I don't have much experience with EMC2, and I don't have all the information I need for configuration.
Need help with defining:
- driver characteristics, time, space, hold, setup...
- Parport base address
Not sure about parallel port setup. The man told me he remembers pins from 2 to 7 were axes and direction, all other were unused, except amplifier enabled what was pin 14 or 17. I have doubts, I think pin 1 should be something, ESTOP Out?
Thanks a bunch for any comment!
