585,922 active members*
3,677 visitors online*
    Mar 2014
    Fanuc OO-P - DNC
    Hi All,
    This is my very first post. I really need some help regarding setting up a DNC for a Fanuc series OO-P.
    I would need to know what parameter numbers to change. Could someone please help me on this. I found a lot of documentations online with settings to change but, I figured that these settings are machine specific. I could not find any documentation for Fanuc Series OO-P.
    I will be very greatful for your help on this regard.
    Kind Regards and Thanks
    Christi Das Devathala
    Jan 2009
    5
    Re: Fanuc OO-P - DNC
    Quote Originally Posted by cddevathala View Post
    Hi All,
    May be here:
    DNC software. CNC and DNC settings for Fanuc 0-P.
    Arthur Grasin, AGG Software
    (DNC Precision, CNC Syntax Editor at http://aggsoft.com)
    Mar 2014
    Hi aggsoft,
    Thank you for your prompt reply. The solution in the link you have sent is exactly what I have done. No Joy.
    I figured that setting PARAM #340 and #341 should set the communication path, but seems like this is not happening. I looks like more of a hardware issue. I also need to examine the PC code in the machine. I guess its not setting the correct bit
    Please lets us know, if you have come across other issues on this regard.
    Aug 2018
    14
    Hi cddevathala
    I have too a machine used FANUC 00-P as same as your machine. And i don't know configure these parameters in order to communicate with DNC.
    Because i tried parameters for FANUC 0-P but can't transmit program to machine.
    So did you fixed your error?
    Please help me. Thank you.
  1. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  2. Replies: 10
    Last Post: 03-02-2013, 05:00 AM
  3. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
