Hello, I just got a 1987 Daewoo Puma 8 lathe I know how to program the tail stock with the M codes my question is I have a part that is shorter than what the distance is between the chuck and the center can you move the tail stock forward? I looked in the parts drawings and it looks like there is a nut in between the base and the tail stock but the only way I see to be able to loosen it would be to remove the tail stock move the base then reinstall and re tram ? does any body have a similar lathe that has had to move it ? or is it made to stay in place? Thanks
