Well, I have started my router build. I am making it out of 8020 exrusions, and it will be used to cut mostly aluminum, also some abs will be cut with it. It will be 50x36, with a cutting area of around 28x40, I just want it to cut around a 2x3 foot section of material with bits up to 1", for when I start using a spindle besides the router that I plan on buying. I will have pics posted shortly. I have all of the linear bearings and I ordered the ballscrews. I will put some pics up of my bearings, and what I have started on, some of the parts should be arriving next week (the rest of my 8020 and my ballscrews).
-I want to be able to cut at 100" per minute, what size motors do you think that I need?, I was thinking 640s or 990s with a 400ish motor for the z axis. I am using 5/8" rolled ballscrews with a .2 pitch, with double bearings on both ends.
-I plan on using geckos, but what power supply would be good? Also can you use a seperate power supply for each axis? Are you guys in the US using 220 to power your power supplies, or is 120 sufficient?
-Is mach three the favorite software out there?, or are there others that are affordable and work well?
I have adquired pretty much all of the physical parts, now it is just to the electric stuff. Any help or advice would be greatly appreciated.
