Guys
My CRT has started to get dull then bright ( normal brightness) the dull. You get the idea. The other day I ran 3 parts in a row with nothing visable on the screen at all. Started to get worse and worse lately. I have also had rs232 problems so not sure if the CRT/puncher card runs both parts of the machine.
Would consider a LCD retrofit if the CRT is stuffed but if a card is stuffed then a new screen won't help.
Is what I am experiencing typically of the symptoms experienced when the CRT is about to die?
Cheers.
