Re: Need Help JQ 1290 laser down on power all of a sudden
Originally Posted by
Dave Matthews
Hi All, New to the forum, but have a JQ1290 80W laser machine. Have had is since November 2013 and was bought second hand. In good condition and works very well indeed for what I use it for. Anyway, today as I was using it cutting some 3mm MDF as normal and all of a sudden it started to loose power from the 80% that I was using as per normal and now just indicates 5% power on the mAh meter on the top of the machine even though the program is set at 80%. Mirrors and lens are clean and water is running perfectly through the chiller unit.
Any ideas. is it the laser tube or the laser power supply?
Thanks for any replies. Dave
Looks like tube. But only looks.
You may check you laser power supply imiedietly if you do not afraid elekticity :- D
Turn machine off and wait half an hour.
Than mount unisolated (5-10mm) Ground cable side by side with unisolated Anode (red) cable that normally feeds your laser tube.
About 30mm one from another.
Take care when you strip isolation wrapped around laser anode input. It is metal-in-glass and very fragile.
Set those cables on a piece of wood isolated from machine body and far from any human.
Than set your laser machine to 100% power and about 1-1.5 second time.
Move away more than 1 meter off those cables and fire laser.
You should see pefect, strong and stable arc welding both wires.
If there is no arc or arc is not strong and stable than you may change you PSU.
Good Luck
CNC lasers, constructions, service
