585,589 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus Pro with servos and 4th axis
Page 11 of 11 91011
Results 201 to 218 of 218
  1. #201
    Aug 2007
    359
    Re: Torus Pro with servos and 4th axis
    maybe not quite as flattering. I think I isolated the spindle rpm changes to the estop being flaky. The factory one had kinda fallen apart, so I put in another one I had.....it was the flaky one. After removing it and jumpering the wires together, I haven't had any rpm fluctuations like that.
    https://www.youtube.com/watch?v=pG8XQRubK1E
    Don't have to be too bright to be me
  2. #202
    Aug 2007
    359
    I didn't put the lathe ops here, but I do have vids of them on my channel. This vid is actually pretty cool......at least I like it....especially the chamfering op at the end.
    https://www.youtube.com/watch?v=FT-wimO5erQ
  3. #203
    Aug 2007
    359
  4. #204
    Aug 2007
    359
  5. #205
    Aug 2007
    359
  6. #206
    Aug 2007
    359
  7. #207
    Aug 2007
    359
  8. #208
    Aug 2007
    359
  9. #209
    Aug 2007
    359
  10. #210
    Aug 2007
    359
  11. #211
    Aug 2007
    359
  12. #212
    Aug 2007
    359
    https://www.youtube.com/watch?v=YPUON2Iq3XA
    - - - Updated - - -
    Maybe I shouldn't wait 10 months to post what I'm up to. lol
  13. #213
    Aug 2007
    359
    LOL!!! My last post said I shouldn't wait 10 months to post on here........and now it's been over 3 years.
    I'll see if I can post a few vids here of stuff dealing with my mill.
    How I set tool lengths
    https://youtu.be/8CeRj4nC4qI
    A chip guard/shield I added to the Z axis
    https://youtu.be/-us-zx77ri4
    A shelf I made for the coolant
    https://youtu.be/0nMwSwVYHV4
    What I did for a tank....way better than the laundry soap jug in the shelf video
    https://youtu.be/pp38rAuSeQ0
    Shower curtain chip containment
    https://youtu.be/ykI_sX42H8A
    I love these jaws!!! I can grab the saw cut sides without having to clean them up first.
    https://youtu.be/U2n9wmq7GJw
    Replacing the rear Y axis bellows
    https://youtu.be/Hi-yGh_YYfU
  14. #214
    Aug 2007
    359
    Modifying a 13" set of rotors
    https://youtu.be/ZLlprAAAUAY
    Bit of mill turning. I now have a Tormach 15L Slant Pro to do this work on.
    https://youtu.be/FDupddeBuJ0
    Thread milling - testing and final use
    https://youtu.be/tOkmPqu8Vl0
    https://youtu.be/fdt6nXp5uEk
    https://youtu.be/lGoBZnblXkY
    "One off" set of brackets I did.
    https://youtu.be/oS9iUqjaSVE
    https://youtu.be/FxM7Hc3m1XA
    https://youtu.be/w_9fH71qNi0
    A couple of upper control arms. One is solid, the other is two pieces
    https://youtu.be/9okeKNoYEjA
    Ball joint covers for the above arms. I stalled/crashed the spindle in the just after the 1min mark
    https://youtu.be/zRDEdBt44vw
    Nearly wet myself
    https://youtu.be/6u4CaFaiSNg
    There's more on my bluehandsvideo youtube channel, so I'll call this enough for now.
  15. #215
    Dec 2009
    594
    I watched the first thread milling video. From my experience I needed to adjust the nominal diameter of the thread mill in my software to get proper fits. Each thread mill is a bit different.
  16. #216
    Aug 2007
    359
    kvom.....good to know. Thanks! It's the only thread mill I had and that was the first time using it. I'll probably have to go through the entire testing process again when I have to do it again. lol
    hhhmmm......the forum won't let me edit any of my posts....need to change one of the vid links.
  17. #217
    Aug 2007
    359
    I noticed in #214 above that the same vid was linked twice. I guess the forum has a time limit on when you can edit. Not that anyone is watching, but here's the link to the one piece UCA made from a water jet cut blank.
    https://youtu.be/cSjm8D8Ggnw
  18. #218
    Dec 2009
    594
    Interesting that you chamfered the soft jaws. Never needed to do so myself.
Page 11 of 11 91011
  1. Torus Pro vs Torus vs Pulsar vs PM45-CNC
    By Titaniumboy in forum Novakon
    Last Post: 01-28-2014, 06:47 PM
  2. Two servos for Y axis?
    By thunderdork in forum Servo Motors / Drives
    Last Post: 08-14-2012, 12:16 PM
  3. Need 3-axis CNC tabletop with servos
    By gemstoneartist in forum Want To Buy...Need help!
    Last Post: 04-11-2011, 07:28 AM
  4. BMC 25 - Z Axis creep when servos off.
    By gthlm in forum HURCO
    Last Post: 11-30-2010, 12:56 AM
  5. 5 axis servos
    By mtk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2008, 01:14 PM
