So I have a part made from .5" thick HDPE that gets machined down to .2 thick. I was able to hold it with the talon jaw vise, but by the time I flipped the part to machine secondary features, the plastic was getting pretty thin and floppy. Although I could make the part, surface finish and tolerances get worse as the vibration increased. So I designed a fixture that was the negative, of the first side of the part. A deeper pocket (vacuum volume) with vertical support pins keep the part flat under vacuum. Then thread milled some NPT holes for the PVC. Now I needed a vacuum source. So I rigged my shop vac (one of the smallest ones Rigid makes I think) up to the PVC. I can't find any specs on how much vacuum it can pull, but it felt pretty good "by feel". I new this would be the risky part of not having enough hold down force. I caught one edge that lifted and broke vacuum at 110"/min and ~.15" deep with a .5" end mill. I slowed it down to 60 and everything ran great, so i made four more. I'll eventually get a dedicated blower/pump and bump the speeds up. I've found some bypass blowers (don't depend on flow through to cool the motor) that can pull 120" H20 for under $100.00. If my leak rate is low enough, I could go with a diaphragm pump. Shot some video between too changes.
https://www.youtube.com/watch?v=khni...ature=youtu.be
