585,683 active members*
4,874 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Air gun Off Command
    Jul 2009
    93
    Air gun Off Command
    Hey All- So I'm trying to edit the post processor to add my air gun to the program. I found out how to change the M code in the Haas VF post processor to turn the air gun on but can't figure out where to edit to have it turn the air gun off.... In my post it's line 707 - Coolant Air Mode. I changed that to M83 (which turns the air on), but there is no code to turn it off. Anyone have any ideas?
    Thanks!
    -Nate
    Jun 2008
    1838
    Re: Air gun Off Command
    Quote Originally Posted by nfrees114 View Post
    Thanks!
    -Nate
    Nate
    The standard coolant off command is usually M09, it normally turns off all/any coolant modes, this is on line 674 as below, no idea what HAAS use for coolant off but that line I reckon is where you should be putting the HAAS M code in place of the M09.
    674. Coolant off String? "M09"
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jul 2009
    93
    Quote Originally Posted by The Engine Guy View Post
    Nate
    Regards
    Rob
    Hey Rob- Yep I found that one. But if I change that to the M84 command (which is air gun off), then if I try and toggle back and forth between using an air gun on some tools and coolant on others than it won't turn the coolant off right? Or do I add a string for "air gun off string?" and then put M84? I didn't know if you could add strings or not?
    Thanks for the quick response!!
    -Nate
  1. while command?
    By davidperry3 in forum Mach Software (ArtSoft software)
    Last Post: 10-04-2011, 02:15 AM
  2. G54 command
    By bfedger in forum G-Code Programing
    Last Post: 04-17-2010, 06:51 AM
  3. G68 command
    By Ashish B in forum CNC Machining Centers
    Last Post: 01-23-2010, 05:25 AM
  4. G03 COMMAND HELP!!
    By hkfanatic in forum G-Code Programing
    Last Post: 08-04-2008, 09:14 PM
  5. what is the same command?
    By hop in forum G-Code Programing
    Last Post: 06-20-2006, 11:24 AM
