585,981 active members*
4,128 visitors online*
Results 1 to 8 of 8
    Mar 2011
    61
    Auto Z Touch Plate
    I've got a CNCRP 4824 Pro. The touch plate is using pin 13 as its input and I think I've confirmed it's working because I can trigger it by tapping the alligator clip to the brass plate and getting confirmation of pin 13 from Mach3. The VB code is entered as suggested, Mach3 restarted.
    When I start Auto Tool Zero the bit ignores the contact with the brass plate and has to be stopped with the EStop. If I clip the alligator clip to the bit, some motor (Z stepper?) "thumps" loudly and rapidly and nothing moves.
    I believe I've followed the setup correctly; the results would suggest otherwise. Any help as to where to look for the problem?
    Thanks for your help.
    Scott
    Mar 2011
    61
    Re: Auto Z Touch Plate
    Some more info for your dining pleasure. When I start the Auto Tool Zero and the spindle is descending, if I touch the alligator clip to the bronze pad (without the tool touching the pad) the Z stops immediately and retracts as it should. I assume this establishes the Auto Tool Zero macro is actually working. When the clip is attached to the tool in the spindle, and I engage the Auto Tool Zero, Mach3 assumes the bit is ALREADY touching the brass pad and the motor noises are the Z stepper trying to stop and ascend at the same time? This implies a short between the spindle and the BOB?
    Scott
    Mar 2004
    1806
    do you have pin 13 connected to the touch plate or to the gator clip???? Basically, the tool IS grounded to begin with (although intermittently).
    Pin 13 should be tied to the touch plate (insulated from the machine) and the gator clip should be tied to ground.
    my .02
    Art
    AKA Country Bubba (Older Than Dirt)
    Mar 2011
    61
    Give that man a cigar! It was wired backwards. All is well now.
    Thanks Bubba.
    Scott
    Mar 2004
    1806
    Thanks, but quit smoking years ago:}) Just glad some of my prior experience could be of benefit to someone else.
    Glad you got it working as it is a real handy tool to have.
    Art
    Mar 2011
    61
    Beer?
    Mar 2004
    1806
    Been known to do that:})
    Art
    Jul 2013
    608
    mine, doesn't work sometime when the alligator clip in on the bits. I sometimes hold it to the tool holder and then it works consistently... not sure why.
  1. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  2. Auto tool setter / touch plate ?
    By chrisnis in forum Machines running Mach Software
    Last Post: 04-06-2013, 12:24 AM
  3. Tormach Auto Z Zero Touch off Plate??
    By BigChad in forum Tormach Personal CNC Mill
    Last Post: 09-22-2011, 03:18 AM
  4. Auto touch off?
    By FozzTexx in forum LinuxCNC (formerly EMC2)
    Last Post: 11-25-2010, 12:31 PM
  5. Touch off plate
    By rich_cree in forum Benchtop Machines
    Last Post: 06-03-2010, 06:05 PM
