585,719 active members*
4,110 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Just got a used VF3, Tool pocket numbers are all over the place
    Nov 2005
    164
    I just took delivery of a 2001 VF3 today and it seems as if the previous owner changed all of the tool pocket numbers for his own needs. For example when pocket #1 is facing the spindle it shows as tool 5 in the tool offsets page. Is there a way to restore the numbers back to the factory default so they are all in order? Its a side mount changer.
    Jim
    Jul 2005
    12177
    Re: Just got a used VF3, Tool pocket numbers are all over the place
    You need to get hold of the manual and read all about pocket and tool numbering with the side mount changer, they are not the same number. Furthermore when the machine is running the tool number stays the same but the pocket number in which it is stored changes.
    Nov 2005
    164
    Thanks Geof....I got it figured out. This is the first machine Ive owned with a SMTC so its a small learning curve.
  1. SprutCAM Tool Library tool numbers
    By MichaelHenry in forum SprutCAM
    Last Post: 06-29-2016, 02:30 PM
  2. Negative tool numbers
    By declanhalpin in forum MadCAM
    Last Post: 02-14-2013, 07:56 PM
  3. Tool numbers not saved with template
    By Damien Gajda in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-06-2012, 10:02 PM
  4. Tool Numbers - recommendations?
    By Scott Kelley in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-29-2009, 04:26 AM
  5. Tool Numbers
    By Mike Mattera in forum EdgeCam
    Last Post: 02-04-2008, 05:18 PM
