Hello Everyone, Here is my problem,
Chinese (Rabbit Laser Engraver) (Model- HX40B) Laser Engraver Not Firing While Running NewlyDraw Software!
This machine has a New Laser Tube and I can Test Fire the Laser while holding down the Upper left green button and the Laser test button! I called the company and spoke with a very knowledgable person on the subject who asked me to send him some pictures of the inside wiring, which I sent! After his inspection , he said that it sounds like a short in the wiring somewhere! I have looked thru this machine so much and I found 1 broken wire and repaired it, but this didnt fix the problem! Im so frustrated with this machine and ready to get it going now! Also, You can run a program in the Newlydraw Software and hold down the upper left green button and the Laser Test Buttons and the machine will engrave the pattern, but wont shut the laser beam off between profiles!
Any help would be GREATLY APPRECIATED!! Thanks in advance!!
