585,737 active members*
4,433 visitors online*
Results 1 to 13 of 13
    Sep 2003
    9
    Question Charmilles Robofil Wire Edm
    I have an older Charmilles Robofil wire EDM that I'm trying to get running. It's a model CH-552 with type #2222 control & type #1222 power supply. When I use the commands MOV & MOR (basically like MDI move absolute & realtive) the machine works & cuts fine. When I use the commands CTA & CTR (manual machining absolute & realtive) the tank fills, power supply kicks in, the wire starts going, everything basically looks like it's kicking in to run but the machine will not move. If anyone has any experience with these machines I'd really appreciate any help offered. I haven't worked on one of these before so it may be something really simple that I don't know about. Thanks!
    Aug 2003
    17
    do you have a tec file loaded when you use ctr are you telling it which axis you want it to travel in
    21
    CHARMILLES
    IS THERE A PEICE OF WIRE SOMEWHERE SHORTING THE MACHINE OUT??? CONTACT CHARMILLE THEY HAVE GREAT SERVICE
    Aug 2005
    10
    Do You Still Have Rebofil 552 Edm I Just Got One With No Manual,do You Have Manual I Need Your Help
    Thank You
    Khanh-vu
    Aug 2005
    10
    Thank You
    Khanh-vu
    Sep 2007
    10
    I work on a 20 year old Charmilles Robofil wire EDM too ... but only from a week ago ... I gotta tell, the machine is a lil bit tricky ... 4 example .. my upper water pump wont start if i don't insert or just check the technology or wire every time i start the machine ... try that ... if i hear something new i'll let u know..
    paul.
    Sep 2007
    10
    CTDB2003 i have the complete manual ... but it is in german .. and it's at work
    Sep 2007
    10
    One question ... do u write ur code by hand or use converter ... and if u do use a software wich one ...
    Mar 2011
    7
    Question My machine robofil200 have an error E666
    My machine robofil200 have an error E666 anyone know how I fix the problem, in the screen say E666 Electr. Sensor Error, I do al the steps but the machine mark the same error , anyone know how do I fix?
    Where is the position of the electrical sensor to use the wire alignment...
    Thanks.......
    Sep 2012
    15
    Robofil 200
    Hi
    I have just purchaced Robofil 200 wire edm. Not started it yet.
    How did u solve the problem of E666 error.
    yssvaff.
    Oct 2012
    e666
    Quote Originally Posted by yssvaff View Post
    Hi
    yssvaff.
    Hi the deionistaion is too high or clean the grey interface who is recover by plastique.
    BR
    :wave:
    Yannick Goering Technical and Sales Manager
    EDMSwiss SARL Used Charmilles specialists
    Jul 2014
    8
    Re: Charmilles Robofil Wire Edm
    who is grey interface becouse i have the same problem my machine charmilles wire 310
    Aug 2017
    And I have the same problem with the E666. Is the electro sensor on the head through which the wire passes?
  1. Charmilles Robofil 310 wire breakage problems
    By chrisgraf2 in forum EDM Discussion General Topics
    Last Post: 01-22-2014, 06:33 PM
  2. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  3. Vero Peps Wire EDM Camtek and Charmilles Robofil 440
    By tewkesbury129 in forum EDM Discussion General Topics
    Last Post: 09-07-2012, 10:06 AM
