One of our operators is having an issue with the consistency when he programs a taper.
This is the example he showed me - see picture
He programmed a .01mm taper and then measured every inch to show the inconsistencies.
If you notice in the picture from left to right the measurements are (in mm):
.095 .095 .092 .094 .098 .098 .100 .100 .103
The diameter gradually goes down and then goes too far before coming back up to be too large.
We have played with the x-axis backlash parameter BS15 and that didn't seem to do anything beneficial.
What do you guys make of this problem?
I will add that the spindle, turret, and tailstock have all been indicated to within .0005"
Its a QT-30 with a T-Plus control.
Thanks in advance and let me know if you need more info.
