I am wiring up to use G213V drivers which need 5v to disable the motor drivers when the Mach3 E-stop is pressed. Right now Mach3 outputs 5v on the ENABLE pins when the you click on the RESET to take it out of E-stop mode but doesnt output anything when its in E-stop mode. This is my first experience with Mach3 so go easy on me.
How do i output 5v when its in E-stop mode only?
