Hi Kiethkyll,
1) Mach3. Config. Ports & Pins. Do I enter an address for Port 1 and 2?
No. Parallel Ports are not used when using KFLOP. Just leave the defaults.
X & Y are analog. Do I enable them in Motor Outputs, or just the Z (stepper) axis?
Yes. Mach3 needs to have those enabled or it won't generate the motion for the axis. Enable them and set the to a dummy port like 0.
3) KMotion. Axis. Enable activates closed loop control. Hitting a limit switch disables. I am using Opto 6 and Opto 7 (Kanalog bits 150 & 151). How do I turn these on/off instead of Enable?
3A) How do I turn Enable back on?
I think you should do both. Disable the KFLOP Axis channel and the amplifier. See the watchenable.c example:
Code:
#include "KMotionDef.h"
main()
for (;;) //loop forever
WaitNextTimeSlice();
if (ch0->Enable)
SetBit(152);
else
ClearBit(152);
HTH
Regards
