586,024 active members*
4,229 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2014
    22
    Pro 4848 build
    Hello everybody, i ve just ordered the first parts for a 4848 pro and just started building the base for that.
    Very excited already, i ll post some pictures when the base is done.
    Nov 2005
    655
    Re: Pro 4848 build
    Good luck with your build...... can I watch?
    Cheers,
    Walking is highly over-rated
    Mar 2011
    59
    Re: Pro 4848 build
    Welcome Aboard!
    Go ahead and post some pictures as you are building the base. We've seen some pretty unique table ideas here.
    -- Bernie
    Mar 2014
    22
    Re: Pro 4848 build
    Here are some pictures for the table and the base.
    Mar 2014
    22
    Re: Pro 4848 build
    Wheels are here
    Mar 2014
    22
    Nov 2005
    655
    Re: Pro 4848 build
    Are you building a room around it?
    What size items are you planning on running?
    Looks like a nice machine!
    Mar 2014
    22
    Re: Pro 4848 build
    Hi, yes i am building a room for the noise, i am gonna use the full size of the table.
    Nov 2005
    655
    Re: Pro 4848 build
    Good idea for the noise but, it looks tight in there.
    Cheers,
    Mar 2014
    22
    Re: Pro 4848 build
    It's a little tight but still very functional. Here are some more photos of the finished room and from the first measurements.
    Attachment 242636
    Attachment 242638
    zanst Guest
    Re: Pro 4848 build
    Nov 2005
    655
    Re: Pro 4848 build
    Nicely done! I like the controls on the outside of the room.
    When I first saw the earlier photo of the room(while building the room), I saw the computer and monitor in front of the machine. I could picture myself knocking the monitor off with a piece of plywood. lol
    Nicely Done!
    Mar 2014
    22
    Re: Pro 4848 build
    Yeah, the plan was having the controls outside since the beginning, its nice to watch it from outside through the glass without the dust and the noise
    Apr 2010
    82
    Re: Pro 4848 build
    how closely were you able to tram the machine?
    Mar 2014
    22
    Re: Pro 4848 build
    Have a look,
    - - - Updated - - -
    Mar 2014
    22
    Re: Pro 4848 build
    Mar 2014
    22
    Re: Pro 4848 build
    After we moved to a new house recently i managed to finish my machine and i realized i have a problem that i cant solve.
    I tried to cut this tutorial from the free trial version of the Cut2d and it seem like my repeatability suffers.
    It starts fine and as the cut is going the whole cut is shifting to the point is almost destroys the job completely at the end.
    I tried everything i can imagine so far, i started by slowing down to 20%, then i cleaned the rails to make sure the machine run smoothly, after that i checked for loose pinions and the i disengaged the motors to make sure i dont have any stiff points, rechecked the tension of the belts and cleaned the racks.
    Also another weird thing that i dont know if it is relevant is that when i export the cut from Cut2d and imported to mach3 it is huge, i have to scale it down to 0.1 on all axes to be at the right size, i dont know why is this happening even though i made sure i am exporting the right format from Cut2d and i have the same units everywhere, mm in my case.
    Here are some photos from some of my test cuts.
    Attachment 253610
    Attachment 253614
    Attachment 253612
    Attachment 253616
    35538
    Re: Pro 4848 build
    For the size issue, in Mach3, go to Config > Select Native Units, and make sure it's in inches.
    If it is, make sure it's jogging the correct distance, and make sure Mach3 is in inch (G20) mode.
    Also, make sure that you're using an inch post from cut2D.
    As for losing position, try reducing the acceleration by 25-50%
    Mar 2014
    22
    Re: Pro 4848 build
    Why change to inch ?
    i use metric everywhere both in mach 3 and Cut2d, metric is my native measurement unit.
    As with the acceleration i reduced it by 80% as i stated in my post and still have the same problem.
    35538
    Re: Pro 4848 build
    Sorry, I thought you were using inches. Leave everything in metric.
    Are you're drawings done in cm, instead of mm?
Page 1 of 2 12
  1. A CRP Pro 4848 Build North of the 49th
    By MobiusConcepts in forum Avid CNC
    Last Post: 12-09-2015, 04:56 PM
  2. Pro 4848 build
    By cbr929 in forum Avid CNC
    Last Post: 04-16-2014, 12:50 AM
  3. Completed Build - CNC Pro 4848
    By Gilrock in forum Avid CNC
    Last Post: 02-07-2014, 06:47 PM
  4. Pro 4848 z axis issues
    By peterkallas in forum Uncategorised WoodWorking Machines
    Last Post: 12-06-2013, 12:29 PM
  5. CRP 4848 Works Great!
    By SteveSy in forum Avid CNC
    Last Post: 09-28-2013, 06:08 PM
