585,875 active members*
3,934 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Siemens 840D/Hyundai 30M Post for Gibbscam
    Has anyone got a siemens 840D post to suit a hyundai 30M lather with Live tooling/C-axis or alternatively just a siemens 810C/840D 2 axis lather post for gibbscam???
    Big thanks to the people who have supplied me with siemens 810d posts, but unfortunately I actually need either an 810c or 840d post as the 810d post is a fair bit different or else maybe it's just in this part of the world they are different.
    Aug 2006
    4
    hi friends,
    I am Nirmal.I need a post processor for sinumeric 810D in mastercam.Kind hearted friends please help me to solve my problem.Thank u friends
    Sep 2007
    37
    siemens 810d post for mastercam v9.1
    hey i think i will join the line asking any souls out there if they have a post processor for the siemens 810d turning, for mastercam v9, this controller drives me nuts every time you think it is sorted out it comes and bites you in the ass with another trick up its sleeve, help help help!!!!
    Jan 2008
    5
    Postprocessor for Gibbs
    Quote Originally Posted by atmosports View Post
    Hi
    Do you still have the post for Siemens 840D to Gibbs
    I would be very pleased if you could send me one or if you know where to find one.
    B/R
    Fredrik
    Jan 2008
    5
    Bakes1 has what you seek....reply to thread and we can talk
    Jan 2008
    5
    Quote Originally Posted by Bakes1 View Post
    Hi
    I´ve been told that both Siemens 810D and 840D should work. I f you have any of them, please send to me so I can make a test.
    /Fredrik
    Jan 2008
    9
    I have:
    Mill Posts:
    Siemens - 810m, 820m, 840m, 850D, 850pen, and 840c
    Lathe Posts:
    Siemens - 801t, 805, 810t, and 820t
    Hyundai HiTrol - 805, 840, and 840c
    Chad
    Jan 2008
    5
    Quote Originally Posted by toolman of NC View Post
    I have:
    Mill Posts:
    Siemens - 810m, 820m, 840m, 850pen, and 840c
    Lathe Posts:
    Thanks for your help but these posts doesn´t fit this machine.
    /Fredrik
    Aug 2005
    70
    Hello everyone,
    You can find posts right @ e-mastercam.com
    Sep 2008
    12
    IS IT POSSIBLE TO SEND ME SIEMENS 810D MILL & LATHE 810,820 FOR MASTERCAM 9
    THANK YOU
    KUMAR
    E-MAIL [email protected]
    Sep 2007
    37
    hi there i never found a post,
    but what i did was i modified the hitachi post in mastercam , which is kind of similar because it uses i and k incrementals, what i found out was the siemens controller accepts straight g-code, but you got to strip all the bells and whistles , so i went thru the code in the post removing strings which generated the bells and whistles although it is not absolutely perfect, and i still have to add the tool in at the beginning, (eg; T01), it works good,
    i use cimcoedit5 professional , http://www.cimco-software.com/ , to view the code to see all is well,
    in the siemens controller you also need to change it over to g-code for it to recieve the code and work, also when when posting you need to change the file format to .mpf , hope this helps, i will try and upload my modified post
    Attached Files Attached Files
    Sep 2008
    12
    Hi! could you please send those posts for me.
    thank you.
    kumar19
    e-mail [email protected]
    Sep 2007
    37
    Smile FILES ATTACHED
    hi there the files are attached on the last reply, they are zipped and have instructions inside, just read the readme.txt for examples
    Sep 2007
    37
    please if anyone is clever on post code feel free to configure the post and upload it back to this forum, thanks
    Sep 2008
    12
    Hi !
    is it possible to share your posts.
    Thank You
    kumar
    Dec 2009
    Postprocessor sinumerik 820M for MasterCAM X or X2
    Hi.
    I need postprocessor sinumerik 820M for mastercam x/x2. If somebody can help me, plese contact with e-mail: [email protected]
    Dec 2005
    12
    apdies
    I have:
    Mill Posts:
    Lathe Posts:
    i need post processor for the siemens 810d mill, for mastercam v9
    pl send me my mail id :[email protected]
    thanks
    Oct 2007
    4
    Sinumerik 805 lathe post
    I have:
    Mill Posts:
    Lathe Posts:
    Hi Chad,
    You stated that you have a post processor available for the Siemens 805 lathe. Will this run from Mastercam?
    Regards,
    Kevin
    Mar 2011
    hello all professional players, I'm mr.toan. I am delighted that today is known to this web and get acquainted with you. I am also very interested in Siemens 840D controller, but for applications in controlled machine turning-milling 5-axis ,IF you have documents on this issue please post them for me and every one, or you can send to my email: [email protected] nhé. thanks a lot sir.
Page 1 of 2 12
  1. Siemens 810 840d post processor
    By madarocsi in forum Post Processors for MC
    Last Post: 06-18-2014, 12:34 AM
  2. Searching post for siemens 840D
    By kurt5 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2014, 07:09 AM
  3. DMC 1035V siemens 840D post
    By PRINT_FX in forum Post Processors for MC
    Last Post: 06-19-2013, 04:59 PM
  4. Post pro for Siemens 840d for Pro/e
    By PeZeD in forum PTC Pro/Manufacture
    Last Post: 01-11-2012, 02:42 PM
  5. Siemens 840D post for FeatureCam
    By cadcamham7 in forum FeatureCAM CAD/CAM
    Last Post: 08-16-2011, 08:17 PM
