585,982 active members*
4,713 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Brand New 3040 and 1 axis is stuck. Please help.
Results 1 to 8 of 8
    Jan 2014
    12
    I got my 3040 cnc machine today. installed the stepper motors and realized that 1 axis won't move. I thought it was the X axis but their paperwork calls it the Y axis. Regardless, it is the long axis that would move the spindle closer and father from me. X axis is the reference photo Attachment 232728 Is there some reason why I can't move the axis by hand? Is there a screw somewhere that they used to keep it from moving during shipping? Please help, as the manufacturer is just ignoring me. Thank you so much.
    Jan 2007
    1795
    Re: Brand New 3040 and 1 axis is stuck. Please help.
    if this is the machine what photo showing, this looking very much like the sharkcnc, and they have own forum..
    on other hand, if machine has screw on axises, they can be moved only with turning the screws..
    Jan 2014
    12
    This is the actual unit.
    Like I said, all the other axis will move except the long axis.They are ball screw so they should move pretty freely. Any suggestions?
    Nov 2009
    314
    Hey,
    Chinese machine XY direction is converse with North American Standards. So your manufacture call long axis Y axis (Actually most north Americans thought it is X axis for long axis). Misunderstanding hehe ,but you have to get used with it or you should discuss this problem before production. Most people ignore this they don't even know this Chinese custom.
    Usually we had fasten pins on rack and pinion routers not balls crew machine.
    If you had ballscrew 10mm on long axis ,that you can moving the gantry closer or farther from you;
    If you had ballscrew 5 mm on short axis, it is possiblely that you are hard to move it by hand. Or some assemble problems.
    Have you tried turned on the whole machine, running it by sofware or DSP handle?
    Regards,
    Ms.Mary
    Dec 2006
    21
    I recently purchased one myself and had the same problem. After looking closer I found that there was 2 screws holding the axis in place. I assumed that this was to keep it from moving in transit. I removed the 2 screws and all was well. Hope this helps!
    Jun 2014
    4
    I think many Chinese producers aim to earn money and ignore their customers after their purchase. With time passes by, they will lose customers.
    Sep 2014
    4
    Hello MadGumby,
    I had the same problem. My long axis was hard to turn by hand and would not move under power. I ended up taking it apart and cleaning what they called grease from the lead screw and the plastic nut. Then I put it back together with new grease and it has been working fine ever since.
    good luck,
    James
    Dec 2007
    2134
    Quote Originally Posted by Allen Smith View Post
    You'd possibly think so, but the quantities that continue to get sold seem to prove otherwise.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  1. Stuck axis on HY-3040 Column Engraver
    By dornm in forum Chinese Machines
    Last Post: 12-19-2017, 07:56 PM
  2. Chinese 3040 CNC with 4th Axis
    By Winterdragon in forum Stepper Motors / Drives
    Last Post: 01-28-2014, 05:02 PM
  3. Z axis problem on CNC 3040
    By BrendonV in forum Maintenance DIY Discussion
    Last Post: 07-21-2012, 07:00 PM
