SteelTailorTM TubeTailor I
Always believe in yourself ! Simple and efficient!
Economical tube cutting solution! Ф60~Ф260mm, Wall thickness ≤12mm.
TubeTailor I CNC Cutting Machine!
1. No need for computer;
2. No need for nesting software, easy operation;
3. Vibration reduction techniques;
4. Most industrial jobs are available in the controller library itself;
5. Automatic torch height to protect the torch and improve the cutting quality.
SteelTailorTM TubeTailor I CNC Cutting Machine!
Cutting tubes easily in 3 minutes!
TubeTailor I was designed with unique and portable concept as SteelTailor enjoyed. Instead of complicated and costly control system and equipment, TubeTailor I chooses 2D structure.
No complicated operation settings required!
Technical Features:
How to use:
Select graphics by controller - Set up parameters - Cut
Three major functions:
Truncation cutting: any angle is available
Tee junction cutting:branch section is adjustable; continuous cutting to main tube with multi-point punching;
Elbow section cutting:any segment can be cut
Program code can be checked and saved in controller or USB
Vibration reduction technique ensures stability and brings better cutting quality.
More information pls visit:
portable tube plasma cutting machine - - SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
Save Cost with TubeTailor I Economical Tube Cutter » SteelTailor' Blog
http://www.cnczone.com/forums/videos...ml#post1473670
Save Cost with SteelTailor TubeTailor I Economical Tube Cutter
