584,866 active members*
5,081 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need Help .Fanuc Servo Amplifier Unit A series
    Apr 2014
    Hello , i have a problem with Fanuc Servo Amplifier A series the unit .I have voltage 230AC between L1C and L2C , the fan of the unit is working but the power of the unit is off . What i should check ? Thanks in advance.
    Aug 2007
    793
    Re: Need Help .Fanuc Servo Amplifier Unit A series
    is there circuit breaker or fuses inside the drive?
  1. Fanuc servo amplifier
    By hotrob1 in forum Fanuc
    Last Post: 04-27-2012, 01:58 AM
  2. Servo Amplifier FANUC
    By Antonio Arguijo in forum Fanuc
    Last Post: 12-07-2010, 03:53 AM
  3. Alpha Series Servo Amplifier A06B-6079-H106
    By M.RISHIKESH in forum Fanuc
    Last Post: 11-25-2009, 04:12 AM
