586,009 active members*
4,899 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor goes in the direction it wants even though the software says up or down
    Mar 2012
    12
    Question Stepper motor goes in the direction it wants even though the software says up or down
    Imagine this : you press the left arrow key, expecting the X axis to move left ... it does ... once in a while. If you repeat this often, the software registers a negative X but the motor turns either one way or the other ... randomly from each keypress. Anyone had that symptom before ?
    When installing the control panel to the wood back plane, there was a spark ... I burned something ... I replaced the burned wire and I tried interchanging things to get that it was the driver that was not working properly *I though) ... now that I have a new driver, I discover that the problem persist ...
    I have to check if I burned a DB25 card or the smoothstepper itself. I have to get my oscilloscope running ...
    Attachment 233526
    Attachment 233528
    Any ideas anyone ?
    Mike quite perplexed at the randomness of the direction of the stepper motor ...
    Mar 2012
    12
    Lightbulb Re: Stepper motor goes in the direction it wants even though the software says up or
    Found the culprit I have XLR style connectors for the motors and the internal part was broken ... cold soldering it appears !
    Resoldered 2 connectors and everything is moving fine ! What a ride
    The randomness of the direction pointed to a broken wire ... and that was exactly it ! Thanks for archives lol
  1. Stepper Motor Only Jogs One Direction
    By jeff johnson in forum Stepper Motors / Drives
    Last Post: 06-11-2019, 03:54 PM
  2. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  3. Stepper motor turns in 1 direction only with mach3
    By MZain in forum Mach Software (ArtSoft software)
    Last Post: 08-14-2012, 02:52 PM
  4. Stepper Motor Spontaneously Reversing Direction
    By JasperBurtonIII in forum Linear and Rotary Motion
    Last Post: 11-25-2009, 06:06 AM
  5. Stepper motor step/Direction conversion.
    By shujah in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2009, 01:49 PM
