586,011 active members*
3,991 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Meldas 320 on a Mighty Comet Spindle Parameters
Results 1 to 10 of 10
    Jan 2014
    57
    A local guy has a Mighty Comet 1000 here for sale, but it has a problem and before I even entertain the idea of buying it I wanted to see if it was something I am even capable of resolving. According to the seller the machine was stored for so long that the batteries died on it and the system lost its parameters. Apparently they got the parameters from Mighty and, I forget if those parameters got the axises running, or if those weren't affected to begin with, but the spindle will not turn on nonetheless because they apparently do not have the correct parameters for it despite what they were given by Mighty.
    I have no experience with this controller or machine, so I'm trying to figure out if this is a common problem that can be remedied with some advice and a parameter list, or if this is something that requires someone well versed in the controller and/or machine to take care of.
    I've poked around the web as best I could and was not able to find any specific info relating to getting an inoperable Mighty back online after it lost its parameters due to battery failure.
    Does anyone know enough about these machines or controls to know if this issue can be easily resolved or am I on a path down a rabbit hole? The only reason I suggest the latter is know there can be issues getting support for these machines from the vendor.
    Thanks.
    Aug 2007
    793
    Re: Meldas 320 on a Mighty Comet Spindle Parameters
    Comet really is Hartfold
    parameters attached
    also somewhere on this forum I uploaded macro for tool changer
    Attached Thumbnails Attached Thumbnails VMC750.pdf
    Jan 2014
    57
    Thanks for that attachment. The only problem is after reading all of those pages I'm thinking I'm biting off more than I can chew, because despite developing software and programming microcontrollers for many years it kind of makes my head hurt thinking about trying to confirm all of that and it looks like there is a lot of ways to screw things up and one way to make it right. When I heard the spindle params were lost I was thinking a handful of entries, but that is a bit more overwhelming than I was hoping it would be. I'll see if I can make sense of how to get the reprogram the controller and see if the owner wants to give it a shot but otherwise I think I'll pass on it.
    Aug 2007
    793
    if you want we could get that machine to run together
    just PM me if you agree
    Hi Guhl,
    I have tried searching for tool change macro for the VMC-1000 Meldas 320 you mention, but I cannot locate it, please repost or email it to me PLEASE!
    [email protected]
    TIA, Carlos.
    Aug 2007
    793
    "Machine parameters -> Macro -> M[01] = 6; type = 1; pogram = 9020"
    To perform tool change type M6 Tx (x = tool #). Not Tx M6
    O9020()
    #1=#4003 (Store modal info)
    #2=#4001 (Store modal info)
    #3=BIN[#1033] (Tool in spindle. "#1033" from ladder)
    IF[#20LE0]GOTO20 (Checking what # of tool was typed)
    IF[#20GT20]GOTO20 (Checking what # of tool was typed)
    IF[#20EQ#3]GOTO20 (Checking what # of tool was typed)
    G49G40G80M5 (Corrections, cycles, spindle off)
    M9 (Coolant off)
    T[#3] (Turn empty pot to spindle)
    G91G28Z0M19 (Go to tool change position, orient spindle)
    M82 (Changer advance toward spindle)
    M11 (Unclump)
    G4X.50M53 (Blow ON)
    G30Z0 (Take out tool)
    T[#20] (Turn to desired tool position)
    #1132=2049 (First action for saving tool # in SP register)
    G28Z0 (Take in tool)
    M10 (Clamp)
    G4X.50M54 (Blow OFF)
    M83 (Changer retract from spindle)
    #1132=2052 (Second action for saving tool # in SP register)
    G4X.5
    M92 (Third action for saving tool # in SP register)
    N20G#1G#2S50 (Restore modal info and cancel orientation)
    M99
    Mar 2008
    169
    Hi Guhl. How are you? I'm a CNC Tecnician. I'm working on a Ecoca lathe. And I don't have plc parameters. Do you know how to load r1900 plc parameters?
    Can I Download the plc program to a PC?
    Thanks so much
    Carlos Cabrera
    Aug 2007
    793
    what parameters do you need?
    Aug 2019
    Hello guhl. I see you have quite some knowledge in these meldas 320. I will much appreciate it if you could help me now how to upload parameters to the machine cause my battery died. I already got the machine parameters from citizen. The machine is citizen L16 from 1993.
    Oct 2023
    9
    Can I have it please?
  1. Mistubishi Meldas M520 and mighty comet tool change issue.
    By 4Rm0D in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-25-2017, 01:01 AM
  2. 1990/92 Mighty Comet Mill Parameters/Mitsubishi control
    By kburns in forum Want To Buy...Need help!
    Last Post: 04-03-2013, 09:42 PM
  3. Mighty Comet with Meldas 520 ATC Problem
    By techscan in forum Mitsubishi controls
    Last Post: 10-13-2012, 03:18 AM
  4. Mighty comet parameters VMC-750 needed/Spindle problem
    By Petro in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-30-2010, 04:27 PM
  5. Mighty Comet with Meldas M0
    By Bert10 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2008, 11:35 PM
