Earlier today I was uploading a program to the controller when the power went out. I now have a "101 Erase Memory". Upon research I found I could reset the controller erasing all programs. I get a "Wrong Mode" text when trying to erase program with Reset and Program. When I tried to change my Parameter write to 1 I received the same message. I have been noticing that if the "Program" HK is pressed twice at any time, you receive a 911 Ram Parity alarm and must reset the machine. After speaking with Accu-Router and being sent to Fanuc's tech department, I am now stuck waiting for a response. Is there another way to reset the alarm and delete the program? I cannot find the previous operators parameters lists so if I am able to reset the machine with PWE I will lose the parameters. Fanuc has led me to believe it is possible to find standard parameters for this machine online, but I am still quite new to this router and type of operations in general. Any help is greatly appreciated!
