585,754 active members*
4,057 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Post generating really small erroneous radii circles?
Results 1 to 6 of 6
    Jun 2010
    89
    Hi again all,
    I am trying to carve out a letter C from a block of material and then run a chamfer along the edge.
    However, my chamfer pass, when posted is producing several arcs with .020 radii that should not be there. I cannot figure out why, or how to eliminate them.
    they are totally extraneous and all lines with radii .020 can be deleted and the post works fine. They seem to occur at sharp the parts of the inside contour where the arcs meet?
    How can I get bobcad to stop producing these small circles?
    As an example the posted code looks like
    Code:
    Arc Ccw X0.8769 Y1.6308 Radius0.515
    Arc Ccw X0.8012 Y1.6353 Radius0.6368
    Arc Ccw X0.7998 Y1.6353 Radius0.6368
    Arc Cw X0.7998 Y1.6353 Radius0.02
    Arc Cw X0.7997 Y1.6353 Radius0.02
    Arc Ccw X0.7966 Y1.6354 Radius0.5923
    I have attached a zip file with the bobcad file, my post, as well as the posted code.
    Appreciate any and all advice please.
    Brian
    Attached Files Attached Files
    Apr 2008
    1577
    Re: Post generating really small erroneous radii circles?
    The chamfer feature almost always generates a toolpath with a small offset from the part profile.
    When connecting these offsets, there are two styles, "Intersectional" or "Roll". "Roll" is considered the safest as it keeps the cutter in contact with the part profile. If you look at this picture, you can see the the "Intersectional" style connection causes the cutter to slightly overshoot the corner. Imagine an extreme case like the point of a needle. If the cutter did not "Roll" over the point of the needle, it would really overshoot the corner and could collide with something else you didn't anticipate.
    Note that deleting the radius will cause the chamfer tool to clip the corner. Bad idea.
    Jun 2010
    89
    Hi I understand those. But it also generates extra curves not at the corners but at the top bottom and left side of the inside of the c. These are not sharp corners but where two arcs meet. These two arcs at this point should be parallel. It should not be the case you describe. I'm wondering if its because my geometry is imported? Is there overlapping lines or something.
    Apr 2008
    1577
    It is the geometry for certain. If I explode the splines at the top of of the inside of the C, I get two arcs that are not tangential. Notice the "bad" arcs are in an opposite direction (CW instead of CCW). That's the tool "Rolling" over the "sharp" point there. If they are not tangent or parallel, there will be a small rollover.
    Because these are splines you are dealing with, you may be able to increase or decrease the Spline tolerance value to get rid of them but the geometry is the true culprit.
    Personally, I would try to explode the whole C shape into arcs, then use Reorganize - Make Tangential.
    Jun 2010
    89
    Thanks SBC. That makes sense. Also, exploding the C into arcs and then reorganizing into tangential arcs made the sharp points go away. Thats great news!
    Brian
    Apr 2008
    1577
    Glad you got it and sorry if I posted like you were a total newb and had no idea what was going on. It's hard to tell someone's user level in the forums so I just put it all out there.
  1. Generating .gpx post-processor
    By MilanTristan in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-15-2022, 11:39 PM
  2. Mach3 PostProcessor generating crazy toolpath. (huge circles)
    By carmamir in forum Post Processors for MC
    Last Post: 02-05-2014, 02:24 PM
  3. Erroneous Z axis emergency stops - how to fix?
    By MarkU in forum Taig Mills / Lathes
    Last Post: 05-06-2012, 08:46 AM
  4. Plasma cut small circles only produce short arcs
    By ronateah in forum Machines running Mach Software
    Last Post: 06-13-2011, 07:47 AM
  5. Replies: 4
    Last Post: 02-26-2008, 03:45 AM
